Intel® Arc™ Discrete Graphics
4067 Discussions
Unplayable Fortnite Performance on Intel Arc B580 (Ryzen 7600X)
Ralpis
I’m posting this here because at this point I’m convinced this is either an Intel Arc driver issue or a serious Fortnite compatibility problem.
I get FPS drops and constant stuttering ONLY in Fortnite.
Every other game runs completely fine (including heavy AAA titles), stable frametimes, normal GPU usage, no issues at all. Fortnite is the only game that behaves like this.
System specs:
  • GPU: Intel Arc B580
  • CPU: Ryzen 5 7600X
  • RAM: 32 GB DDR5
  • Storage: NVMe SSD
  • OS: Windows 11
  • Re-BAR: Enabled
  • BIOS: Fully updated B650 prime wifi II ver.3602
  • Drivers: Latest Intel Arc GPU drivers + latest AMD chipset drivers
What I already tried
  • Windows reinstall
  • DX11, DX12 and Performance Mode
  • Low → Epic settings
  • FPS capped / uncapped
  • V-Sync on/off
  • Background apps disabled
  • Power plans checked
Symptoms:
  • Random FPS drops and microstutters
  • Inconsistent frametimes
  • GPU usage stays low
  • CPU is not bottlenecked
  • Happens regardless of graphics settings
This makes zero sense from a hardware perspective. A 7600X + 32 GB RAM should not struggle with Fortnite at all, yet the game feels worse than on much weaker systems.
At this point I honestly don’t know if:
  • Fortnite is poorly optimized for Intel Arc
  • Arc drivers still have major issues with Unreal Engine / Fortnite specifically
  • Or there’s some deeper scheduling or compatibility problem
What frustrates me the most is that the GPU works great everywhere else, but Fortnite
So I’m asking directly:
  • Is this a known Intel Arc + Fortnite issue?
  • Is there an actual workaround or driver fix coming?
  • Or should people who play Fortnite just avoid Intel Arc GPUs altogether?
Because right now, I honestly cannot recommend this GPU to anyone who plays Fortnite, which is ridiculous given the specs and price.
Any official response or real solution would be appreciated, because I’m completely out of ideas.
JedG_Intel
Hello Ralpis,
Thank you for reporting this issue. Our priority is to target the most popular games and apps to focus our efforts on providing a high quality, stable experience for the broadest set of users. We will continue to improve our software performance and compatibility throughout 2025 and beyond. While we can’t accommodate your request at this time, please watch this article on our website for any possible changes to this situation.
With this in mind, I will now close this inquiry. If you have other questions or concerns, please submit a new inquiry as this thread will no longer be monitored.
Best regards
Jed G.
Ralpis
so fortnite is having this problem on intel arc b580 since december?
