I bought a390 for light gaming. I used to play valorant on Nvidia Gt1030, which is much lower than Arc a380.But my arc a380 It stutters a lot, which makes it bad and dizzy gaming experience.
Hi Chinmoy92,
In line with the link that was sent by Bandit862, please make sure you provide the following basic information when reporting a bug:
- What is the graphics driver you are using?
- Confirm you are using the latest WHQL graphics driver available (let us know the exact driver version you are using).
- A clean driver installation using DDU in safe mode is recommended. Follow this link for instructions.
- You could also test using the latest Beta driver. Our Beta drivers go through all Intel quality assurance processes and are safe to use for evaluation.
- Tell us the name of the game or application and where to obtain it (Steam, Epic, etc.)
- Provide us with the Intel SSU report from your system.
- If you do not wish to submit the SSU report then at least provide us with the following information about your system:
- Processor make and model.
- Motherboard make and model.
- Amount of memory (RAM).
- Operating System version/build number.
- Power Supply make and model.
- Tell us the steps to reproduce the issue (this is very important!).
- For graphics corruption (per example artifacts, textures corruption or lighting glitches) please use Intel Arc Control to capture screenshots or a video showing the bug.
Dean R.
Hi Chinmoy92,
Dean R.
