Intel® Arc™ Discrete Graphics
3548 Discussions
Variable Refresh Rate Support Not Supported for AOC G2590FX
AimlessBot
I have an AOC G2590FX monitor and it no longer recognized as supporting Variable Refresh Rate. Simultaneously, Dynamic refresh rate is no longer available in Windows Settings. This appears to be a driver issue as rolling back to older versions brings back VRR and DRR.
Other things I have tried:
  • Using DDU to uninstall drivers before installing latest drivers.
  • Trying a better DisplayPort (2.1) cable.
Things I have not tried:
  • Installing newer non-WHQL drivers.
Computer Information:
  • Monitor: AOC G2590FX
  • GPU: Intel Arc A770 Limited Edition 16GB
  • CPU: AMD Ryzen 7 3700X
  • Motherboard: ASUS PRIME B550-PLUS AC-HES
  • BIOS Version: 3607 (2024/04/04)
  • System Memory: 32 GB
  • Operating System: Windows 11 Pro for Workstations 24H2 (OS Build 26100.3775)
GPU Driver: 32.0.101.6651
  • Variable Refresh Rate: 30Hz - 146Hz
GPU Driver: 32.0.101.6734
  • Variable Refresh Rate: Not Supported
GPU Driver: 32.0.101.6737
For now, I'll stick with version 32.0.101.6651 since there's nothing specific I need in the latest driver versions. I just wanted to post this in case this wasn't a known issue.
JeanetteC_Intel
Hello AimlessBot,
I'll look into this internally and provide an update as soon as it's available.
JeanetteC.
AimlessBot
Hi JeanetteC,
Thank you for looking into that for me. Let me know if you need any additional information.
Best of luck,
Aimless
JeanetteC_Intel
Hello AimlessBot,
I am still currently reviewing this internally and will share an update at the earliest opportunity. I will reach out if I require any additional information from you.
JeanetteC.
AimlessBot
Status Update: I installed the new 32.0.101.6739 driver to see if that fixed it. Variable Refresh Rate is also listed as "Not Supported".
JeanetteC_Intel
Hello AimlessBot,
Here's an update on your request:
We tested VRR with our latest drivers across a variety of displays available in the market and did not encounter the same issue, indicating a potential compatibility problem with the specific monitor model, AOC G2590FX. I want to set your expectations appropriately, as this issue may not be prioritized by the driver development team soon, given that resources are currently focused on addressing critical issues affecting the majority of users.
To assist further in our investigation, could you please provide the following information:
  • How are you connecting the monitor? Is it via DisplayPort or HDMI?
  • Are you using any adapters or converters?
JeanetteC.
AimlessBot
Hi JeanetteC,
Thank you for getting back to me.
My monitor is connected via a DisplayPort cable without any adapters or converters. The cable I normally use is rated as DisplayPort 1.4 but I also tried a DisplayPort 2.1 cable while trouble-shooting it. Sadly, changing cables did not have any effect.
In case it matters, I also have two other non-VRR monitors that are also connected via DisplayPort. Disconnecting these monitors does not appear to have any impact on VRR detection for the primary monitor. Meanwhile the HDMI port on the Arc A770 is never used.
As a side question, is there a repository of older drivers publicly available? I rolled my drivers back to 32.0.101.6651 because they are the newest working WHQL drivers (as time of posting) on The Download Page. From the numbering, I'm guessing they are on the older side? I would find and report a more precise version where VRR stopped working if more driver versions are available.
Best of luck,
AimlessBot.
JeanetteC_Intel
Hello AimlessBot,
Thank you for providing this update. I'll continue to monitor the situation internally and will share any new information as soon as it's available.
In the meantime, here is a list of WHQL drivers, ranging from the latest to older versions. There are three newer versions than the one you currently have (6651), as well as two older versions:
JeanetteC.
JeanetteC_Intel
Hello AimlessBot,
Please be informed that we attempted to replicate the issue, but we do not have the exact monitor model G2590FX. However, we successfully tested with other AOC monitors.
If possible, please gather an ETL file (instructions are attached).
Additionally, collect the EDID data using an IGCC report.
  • To generate IGCC report for EDID analysis, please follow the steps below:
    1. If IGCC is not yet install on the Windows system, download and install the "Intel® Graphics Command Center" from the Microsoft Store.
    2. Once installed, launch the Intel® Graphics Command Center (IGCC) software.
    3. On the left side of the app, click on "Support" and then on top click "System Diagnostic"
    4. To the right, click on "Generate Report" and you will be prompted to save it as a txt file.
    5. Save the report which can be used for analysis.
I hope to hear from you soon.
JeanetteC.
AimlessBot
Hello JeanetteC,
I've attached the Generated Report. I updated to the latest version, 32.0.101.6793, before generating the report. let me know if I should generate another report using the last known working version.
On that note, here is an updated list of working/non-working drivers:
31.0.101.5593
  • Variable Refresh Rate Support: Supported
  • Variable Refresh Rate Range: 30Hz - 146Hz
32.0.101.5762
32.0.101.6651
32.0.101.6732
  • Variable Refresh Rate Support: Not Supported
32.0.101.6734
32.0.101.6737
32.0.101.6739
32.0.101.6793
Best of luck,
AimlessBot
JeanetteC_Intel
Hello AimlessBot,
I've already received the detailed report. Please go ahead and generate the ETL file. There's no need to create another report using the last known working version. I'll be waiting for the file to continue with the investigation of this issue. Looking forward to hearing from you soon.
JeanetteC.
AimlessBot
Hello JeanetteC,
I apologize for failing to include the ETL file last time. I've attached it as a max compression 7z archive. Let me know if you need anything else.
AimlessBot.
JeanetteC_Intel
Hello AimlessBot,
I appreciate you sharing these essential files. I'll proceed with reviewing the issue internally and will update you as soon as possible.
JeanetteC.
VonM_Intel
Hello AimlessBot,
To better understand the issue with Variable Refresh Rate (VRR), may I kindly ask you to clarify the following:
  1. How exactly is the lack of VRR presenting itself on your system? For example:
    • Is the VRR option completely missing in the Windows graphics settings?
    • Is the option missing or greyed out within Intel Graphics Settings (IGS)?
    • Is the refresh rate stuck at 30Hz or another value?
  1. Have you had the opportunity to test using an HDMI connection instead of DisplayPort to see if the issue persists?
Von M.
AimlessBot
Hello Von M.,
To answer your questions, I will be using the driver versions 32.0.101.6651 (working) and 32.0.101.6793 (not working). My computer is also running Windows 11 Version 24H2 (OS Build 26100.4061).
Q: How exactly is the lack of VRR presenting itself on your system?
A: Games present horizontal tearing with newer drivers but not with older drivers. VRR-related settings are also missing or disabled with newer drivers.
Q: Is the VRR option completely missing in the Windows graphics settings?
A: I assume you mean the DRR option? It is present but disabled with the message "Dynamic refresh rate isn't supported." Windows doesn't show any other VRR-related settings no matter what driver version I am using.
Q: Is the option missing or greyed out within Intel Graphics Settings (IGS)?
A: The Variable Refresh Rate option is completely missing in IGS. The Variable Refresh Rate Mode option is present but disabled with a blank dropdown list.
Q: Is the refresh rate stuck at 30Hz or another value?
A: The refresh rate is perfectly fine. It goes all the way up to 144Hz with no issues.
Q: Have you had the opportunity to test using an HDMI connection instead of DisplayPort to see if the issue persists?
A: From what I can tell, my monitor doesn't support VRR over HDMI but I tested it for the sake of science. Here are the results:
  • VRR was not enabled (both versions).
  • The refresh rate was capped at 119.98Hz instead of 144Hz (both versions).
  • DRR was disabled in Windows Settings (both versions).
  • Variable Refresh Rate and Quantization Range disappeared from IGS (both versions).
  • Variable Refresh Rate Mode was present but disabled.
    • 32.0.101.6651: Disabled with a blank dropdown menu.
    • 32.0.101.6793: Disabled with a dropdown menu that reads "Not Supported".
Here is a side-by-side of what I see with the different drivers in IGS and Windows Settings:
I've also attached an archive with additional setting screenshots organized by driver version and monitor connection (DisplayPort/HDMI). Please let me know if you need anything else.
Sincerely,
AimlessBot.
JeanetteC_Intel
Hello AimlessBot,
I highly appreciated your sharing of the important details that we may make use to further investigate the issue. I'll post an update once available.
JeanetteC.
