Intel® Arc™ Discrete Graphics
4122 Discussions
Water Material Display Issue in Cities: Skylines II and Power Consumption of Intel Arc B580
RiceballFan
1. About water material display issue:
I am currently using the following system configuration:
  • Operating System: Windows 11 24H2
  • CPU: AMD R9 9900X
  • GPU: Intel Arc B580 12GB
I have updated the driver using Intel Graphics Software to version 32.0.101.6257. While playing Cities: Skylines II, I encountered an issue where the water fails to display correctly, resulting in rendering errors.
2. About power consumption issue:
I have observed that the power consumption of the Intel Arc B580 graphics card in idle mode appears to be relatively high. Using HWiNFO for monitoring, the power draw is approximately 30-40W.
  • Is this power consumption level considered normal for the B580 in idle state?
  • Will there be any updates or optimizations in future drivers to improve idle power consumption?
RiceballFan
Additional Information of System:
Ram: 64G ddr5
MB: asus prime x870-p-csm
os:
Windows 11
24H2 26100.2894
RandyT_Intel
Hi RiceballFan,
For graphics corruption (per example artifacts, textures corruption or lighting glitches) please use Intel Graphics Software to capture screenshots or a video showing the bug. Regarding the power consumption for this card in idle mode, let me double-check on our end. I will get back to you with accurate numbers, as I'm unable comment on the readings from third-party software.
Need help? Reporting a bug or issue with Arc GPU? - PLEASE READ THIS FIRST! - Intel Community
Randy T.
RiceballFan
Hi RandyT,
I can't find the screenshots function both in the Intel Graphics Software and Intel Graphics Command Center.
This screen shot is using Windows 11's system PrtSc.
And video is using "Win+G" open the game center of Windows 11, and record video by this function.
Thank you.
RiceballFan
**update
This water display issue has been solved in driver version 32.0.101.6259
Thank you!
RandyT_Intel
Hi RiceballFan,
Thank you for an update since issue has been resolved by the latest driver allow me to help on your concern about power consumption, based on this article power consumption of Intel Arc Graphics cards (even during Idle state) depends largely on the number of displays connected to the card and each display's resolution/refresh rate.
For most supported configurations to achieve optimal power consumption configure the BIOS as follows: High Power Consumption when Intel® Arc™ Graphics Card is...
Please let me know the results after you've had a chance to try this
Randy T.
RandyT_Intel
Hi RiceballFan,
Since I have not received any response from you, I will proceed with closing this ticket. Please note that this case will no longer be monitored.
If you have any new questions or inquiries, kindly submit another ticket, and we will be happy to assist you.
Randy T.
