Intel® Arc™ Discrete Graphics
4067 Discussions
b580 Memory Leak in dcs world
FLYing59
i use win11 25h2; i5-12400f; arc b580;32g,3200mhz memory;
In single-player mode, VRAM usage is relatively low and can handle 2K at 60fps.
However, after entering multiplayer mode, the 12GB of VRAM is quickly exhausted, causing the graphics to lag severely, and the longer it runs, the lower the frame rate becomes. Even after exiting multiplayer mode, the VRAM is not released.
At this point, opening a single-player mission also results in very laggy graphics, sometimes dropping to only 20fps.
p1 single-player task
p2,3 open a multiplayer game
p4 back to the top,the vram is not released
p5 open a new single-player taskIMG_20260122_032241.jpgIMG_20260122_032642.jpgIMG_20260122_032742.jpgIMG_20260122_032808.jpgIMG_20260122_032847.jpg
Mike_Intel
Hello FLYing59,
  1. Was it working fine before?
  2. If yes, what was the last change made in the system before the issue started?
  3. What are the troubleshooting steps that you tried so far?
  4. What is your game launcher?
  5. For me to review the hardware and the installed drivers, please generate the SSU logs of your system. Kindly refer to the link below for the steps:
Michael L.
FLYing59
I have tried clearing the shader cache and lowering the game's texture quality, but the VRAM leak in online mode still consistently occurs.I have generated the SSU logs
Mike_Intel
Hello FLYing59,
Thank you for the quick update.
Upon initial checking of the SSU, I found out that the BIOS of your board and the Graphics are not updated.
Here are my initial recommendation and kindly update me if these will help with the issue.
  1. Please update the BIOS of your board, here is the download link: MAG B660M MORTAR WIFI DDR4
  2. Please update the driver using DDU method. Kindly refer to the link below for the steps on how to perform DDU and the direct link of the latest driver:
How to Use the Display Driver Uninstaller (DDU) to Uninstall a...
Intel® Arc™ Graphics - Windows*
Michael L.
Mike_Intel
Hello FLYing59,
Michael L.
FLYing59
屏幕截图 2026-02-14 181117.png屏幕截图 2026-02-14 181208.png屏幕截图 2026-02-14 181517.png
I update the driver to 8509 today,but the bug still exists.Shared vram cant be released after quit the 3d world,eventhough dedicated vram has been released.
Mike_Intel
Hello FLYing59,
Thank you for the update.
I may need to further investigate this issue and try to simulate this in our lab. For me to do that, I need to gather additional information.
  1. What is your game launcher?
  2. Please send a screenshot of the game's Graphics settings.
  3. Kindly tell us if there is a specific place in the game that would trigger the memory leak
Michael L.
FLYing59
I'm playing the Steam version. VRAM leaks happen every time I play multiplayer mode.
Mike_Intel
Hello FLYing59,
I will do further research on this matter and post the response on this thread once it is available.
Michael L.
Mike_Intel
Hello FLYing59,
I hope you are doing well today.
I just want to update you that I am in the process of simulating this issue. While doing that, let gather additional information that can help me to investigate further.
  1. Please provide the exact Overlay application that you use when you capture VRAM 14gb/12gb
  2. What is the Ping of the server when playing (screen capture the lobby).
Michael L.
Mike_Intel
Hello FLYing59,
I am just making a follow up on the information I requested in my previous post.
Michael L.
Mike_Intel
Hello FLYing59,
I am sending another follow up on the information that I requested.
Michael L.
