Intel® Arc™ Discrete Graphics
4196 Discussions
help with this error
madio215721
Mike_Intel
Hello madio215721,
  1. Can you translate the error in English?
  2. Was it working fine before?
  3. What was the last change made in the system before the issue started?
  4. What are the troubleshooting steps that you tried before contacting us?
  5. For me to review the hardware and the installed drivers, please help generate the SSU logs of your system. Kindly refer to the link below for the steps:
Michael L.
gasoline
Valued Contributor I
I translate especially for you:
The current system configuration is not supported by Intel Graphics Software.
Make sure the Intel graphics adapter is detected and enabled in Device Manager and update the graphics driver to the latest version.
If the issue persists, contact Intel support.
JohnM_Intel
Hello madio215721,
I hope you had the opportunity to review the information I posted. At your earliest convenience, please let me know so we can determine the best course of action to resolve this matter efficiently.
John M.
Oven_21
A few things to try:
  • Check Device Manager → Display adapters and confirm your GPU model (Intel vs NVIDIA/AMD). This app only works with supported Intel iGPUs.
  • Download the latest Intel graphics driver for your exact CPU/GPU from Intel’s site (not Windows Update).
  • If you’re on a laptop or OEM system (Dell/HP/Lenovo), try the manufacturer’s driver — generic Intel drivers can sometimes be blocked.
  • Restart after reinstalling and relaunch the app.
Oven_21
Intel Graphics Software – Unsupported Configuration Issue
I’m seeing a message in Intel Graphics Software saying that my current configuration is not supported. The app launches, but it warns that some features may not work correctly or may be unavailable.
This appears after installing the latest Intel Graphics Software, and the system otherwise runs normally. Drivers seem to be installed, but the software still flags the configuration as unsupported.
Could this be related to:
  • Incompatible or legacy hardware
  • Incorrect driver version for Intel Arc / integrated graphics
  • OS version compatibility
Any guidance on the correct driver or supported configuration for Intel Arc graphics would be appreciated. Thanks in advance to the community and Intel team for the help.
