Intel® Arc™ Discrete Graphics
4063 Discussions
houdini sop line node can not show geometry
gearslogy
software:Houdini 20.5.487
B580
vulkan displayMode: nothing to show
opengl displayMode:
Labels (2)
DhannielM_Intel
Hello gearslogy,
Thank you for sharing your issue with the community. Based on the image you provided, there seems to be a difference when using the Vulkan API. To better assist you, I have a few questions:
  • What is your current driver version?
  • Have you tried using different drivers for testing?
  • Does the issue also occur with different software, or is it only happening with Houdini?
  • Have you performed a clean installation of the driver?
Additionally, to better understand your entire system information, please use the System Support Utility (SSU). This tool will generate a text file compiling all your system information. You can follow the instructions in the link and send the text file here: Help Guide for the Intel® System Support Utility
Also, could you trying this work around and let me know if this will resolve the issue:
  1. Go to %HOME%/houdiniX.Y/houdini.env
  2. Type HOUDINI_VULKAN_VIEWER=0
  3. Save log
Dhanniel M.
gearslogy
1: drivers is up to data
2:The last two drivers have had problems
3:unkown
4:yes
DhannielM_Intel
Hello gearslogy,
Thank you for responding to my inquiry. I wanted to ask if you have tried the following workaround steps:
  1. Navigate to %HOME%/houdiniX.Y/houdini.env.
  2. Type HOUDINI_VULKAN_VIEWER=0.
  3. Save the changes.
If you have already tried this workaround, please let me know if it resolved the issue. If not, I will conduct further investigation into this matter. Additionally, could you please provide the exact version you were using before?
Dhanniel M.
VonM_Intel
Hello, gearslogy.
Have you had a chance to review my previous response? Please feel free to let us know if you need any additional assistance. I'm here to help!
Von M.
DhannielM_Intel
Hello gearslogy,
Dhanniel M.
DhannielM_Intel
Hi gearslogy,
I wanted to provide you with an update regarding the issue you're experiencing. Based on our investigation, the fix for the Geometry problem when using Vulkan in the Houdini application has been implemented in driver version 32.0.101.6732. Please update your driver to latest version (32.0.101.6739). For optimal results, I recommend using Display Driver Uninstaller (DDU) to perform a clean installation. Please follow the steps below for guidance and instructions:
  1. Download Display Driver Uninstaller (DDU)< software and extract the file.
  2. Open DDU ****.exe and run extract program.
  3. Reboot into Windows* safe mode. (Refer to Start your PC in safe mode in Windows.)
  4. Go to the DDU extract path and double-click the Display Driver Uninstaller.exe to open DDU.
  5. Click Close in the Options window.
  6. Select device type to GPU and select device to INTEL.
  7. Click Clean and restart or Clean and Shutdown depending on your needs
  8. Wait the software to finish the process and auto reboot Windows to the normal mode or shutdown.
Please let me know the results after you've updated your driver.
Dhanniel M.
gearslogy
It's working perfectly now. Thank you very much.Great!
DhannielM_Intel
Hi gearslogy,
I'm pleased to hear that your issue has been resolved. I will now proceed on closing this inquiry. If you need any further information, please feel free to submit a new question, as this thread will no longer be monitored.
Dhanniel M.
