Intel® Arc™ Discrete Graphics
3520 Discussions
intel Arc A380 issue with MAXON CINEMA 4D
Rexfrese
I had a older card from NVIDIA GEFORE GT 710 (2GB VRAM) i'm trying to work on a project but it seems after switching to intel arc a380 it seems to lag A LOT. Please help me and these are my specs
CPU: Intel i5 9400F
RAM: 16GB DDR4
GPU: Intel Arc A380 (6GB VRAM)
AlHill
You do not meet the requirements for ARC:
https://www.intel.com/content/www/us/en/support/articles/000091128/graphics/intel-arc-dedicated-graphics-family.html
[W10 is this generation's XP]
Deeksha_S_Intel
Hi Fain,
We would like to inform you that we are routing your query to the dedicated team for further assistance.
JeanetteC_Intel
Hello Rexfrese,
If I may add input from what Super User AlHill mentioned here, your system may not have met the system requirements for the Intel® Arc™ A380 Graphics, but it may still run and/or able to use this graphics card however, there may be performance or stability issues for configurations not listed in this guide.
With regard to the lagging issue with MAXON CINEMA 4D, I hope to get the following details below so we can further check:
1) PC configuration to check further what's causing the issue to happen. This could be possible by downloading the Intel® System Support Utility for Windows* software. When the download is complete, launch SSU.exe.
  • Click Scan.
  • Click Save (.txt). *Attach the log file as you reply to this thread.
2) Please confirm that the 'Resizable BAR' or 'Above 4G decoding' has been enabled.
I will wait for your reply.
JeanetteC.
Rexfrese
Hi!
Newer of CINEMA 4D works completely fine, but the older version have laggy performance no clue why
The reason I don’t want to switch is my assets gets missing in the newer versions.
And i my motherboard does not support Resizable BAR, and i don’t think it would fix the problem.
JeanetteC_Intel
Hello Rexfrese,
I'll take note of these. I just hope to clarify the following:
1) "Newer of CINEMA 4D works completely fine, but the older version have laggy performance no clue why"
Q: Can you please confirm that the application (CINEMA 4D) is working fine with the software latest version along with the Intel® Arc™ A380 Graphics and the "older version" with the "laggy performance" you were referring to is the "older version of the CINEMA 4D?
2) "The reason I don’t want to switch is my assets gets missing in the newer versions."
Q: When you say "switching to newer version gets missing assets", are you referring to switching back to your old GPU (NVIDIA GEFORE GT 710 (2GB VRAM)) or switching back to your software (CINEMA 4D) older version?
3) And i my motherboard does not support Resizable BAR, and i don’t think it would fix the problem.
Q: Were you able to confirm with your motherboard support team, that this system does not have resizable bar or Above 4G decoding'? May I ask what your motherboard make/model is, or can you share your system configuration using the Intel System Support Utility (Intel SSU), I requested previously, so I can help check further?
I hope to hear from you soon.
JeanetteC.
Rexfrese
I'm answering your questions:
Q.1)
A. Yes, the latest version of CINEMA 4D is working completely fine with INTEL ARC A380. But older versions are very laggy.
Q.2)
A. No, i did not meant switching to my previous GPU. i was talking about about CINEMA 4D older Versions.
Q.3)
A. My Motherboard Model is (GIGABYTE B365M GAMING HD) and it does not supports Re-Size BAR/4G Decoding. And My CPU is (Intel Core i5-9400F)
i'm still facing the problem.
Thank you!
Regards.
-Rexfrese
JeanetteC_Intel
Hello Rexfrese,
Thank you for the clarification. It seems to be more of a compatibility and software-related issue. I'll proceed with checking this internally for now and will provide an update once available. Please feel free to share any additional information you might have.
JeanetteC.
JeanetteC_Intel
Hello Rexfrese,
While I am checking on this issue further, please proceed with a clean installation of the latest Intel® Graphics Driver 32.0.101.6647 (WHQL Certified) using the Display Driver Uninstaller (DDU) and let me know if it makes any difference.
JeanetteC.
Rexfrese
Hi!
So before installing the Intel Arc gpu in my computer i already had done a Uninstall of my previous drivers (NVIDIA) and then i installed Intel Arc gpu and installed Drivers.
Should i still do it?
JeanetteC_Intel
Hello Rexfrese,
Good day!
Yes please do. But get the latest version, which was released on March 19th, this Intel® Graphics Driver 32.0.101.6651 using the Display Driver Uninstaller (DDU) and let me know if it makes any difference.
JeanetteC.
Rexfrese
So i have everything you said to do, and i also found out my motherboard supports Above 4G Decoding, and i enabled it and after everything nothing is still working.....
Rexfrese
JeanetteC_Intel
Hello Rexfrese,
I understand that performing a clean installation with DDU of the latest Intel® Graphics Driver 32.0.101.6651 hasn't resolved the issue. I'll look into this internally and provide an update as soon as possible.
JeanetteC.
JeanetteC_Intel
Hello Rexfrese,
I am continuing to investigate and will provide an update as soon as possible.
JeanetteC.
Rexfrese
Any updates regarding about the issue?
JeanetteC_Intel
Hello Rexfrese,
It seems that the older version of MAXON CINEMA 4D is not optimized for Intel Graphics cards based on its behavior. I recommend contacting the application developer for assistance with migrating your settings and assets to the latest version.
I will now close this thread. If you need further assistance in the future, please submit a new question, as this thread will no longer be monitored.
Sincerely,
JeanetteC.
