Intel® Arc™ Discrete Graphics
3526 Discussions
miles morales crashes showing video memory error
TXTfrags31
After launching the game for 2 sec, the game automatically crashes, showing this message. any fix pls, Intel iris XE graphics 8gb ram
Earl_Intel
Hi TXTfrags31,
I'm sorry to discover that you are encountering troubles with your system. To better assist you and find the most appropriate solutions, could you kindly share the essential facts stated below:
  • May I know if your device is a laptop or a desktop? if it's a laptop, what is the exact make and model of it?
  • Is the game working fine before? if yes, what are the changes on the system before you encounter this issue?
  • What digital gaming platform did you download Spiderman: Miles Morales? Steam or Epic games store?
Kindly run this on your system so that I can also gauge the following peripherals and the driver versions that you have:
Intel® System Support Utility for Windows*
Once finished downloading, open the tool, click on scan (leave the default items checked), click next, then save the system information to a .txt file. Please provide us the .txt file.
Earl E.
TXTfrags31
1)It is a Lenovo Yoga 7i 14IRL8 Laptop 2023 release
2)No, the game has not been working when i first installed it.it kept showing the PSstudios then crashing
3)I used steam to install miles morales
Earl_Intel
Hi TXTfrags31,
Thank you for sharing this useful information with us.
Before we proceed, please note that this is an OEM device, we will try to assist you with general troubleshooting steps even if it's something not traditionally covered in our support. However, if the issue still persists, you will have to contact the Original Equipment Manufacturer of your device. Your device manufacturer may have altered features, incorporated customizations, or made other changes to some components for better compatibility with your system.
Try using our generic graphics driver, before you install the latest version, perform DDU first.
Let me know if there will be changes on the issue.
Earl E.
TXTfrags31
Thanks for your help, But the issue still persists. I think i should try contacting Lenovo support to fix it.
Earl_Intel
Hello TXTfrags31,
Thank you for sharing this update.
You're correct; it's important to get in touch with your OEM because troubleshooting didn't resolve the issue.
If you need further assistance, please submit a new question as this thread will no longer be monitored.
Earl E.
