Intel® Arc™ Discrete Graphics
3526 Discussions
performance issues and graphical bugs in Need for Speed ​​Heat
AsterCrash
I'm having performance issues and graphical bugs in Need for Speed ​​Heat
VonM_Intel
Hi AsterCrash,
Thank you for posting in our Community. I’d like to gather a few more details so we can better analyze the situation and provide you with the right support. Could you please confirm the following:
  • Which Intel® Graphics Driver version is currently installed? Have you tried testing with the latest driver available using the DDU tool?
  • Did you install the game via Steam, EA App, or another platform? Could you confirm the game version?
  • What graphics settings (resolution, quality presets, effects toggles) are you currently using?
  • Do the issues occur consistently (e.g., at launch, during certain cutscenes, or in specific maps), or are they random?
  • Are you experiencing similar performance or visual bugs in other titles, or is this only happening in Need for Speed Heat?
  • When you mention performance issues with this game, are you referring to low FPS, stuttering, or both? If so, could you please provide CapFrameX data for this game? This will allow me to analyze performance metrics in more detail and identify any potential issues. Ideally, please share a CapFrameX file that includes at least 2-5 minutes of gameplay.
  • If possible, could you please share any screenshots or a video recording that captures the graphical bugs you’re experiencing in Need for Speed Heat?
I'd like to delve deeper and verify specifics like the graphics models, precise driver versions, and any system errors. Utilizing the Intel SSU tool will enable me to collect detailed information about your system setup, which could aid in identifying the underlying cause of this issue.
Have a nice day!
Von M.
AsterCrash
at the moment only in it in need for speed, yes consistently, the graphics are set to high before ultra
VonM_Intel
Hello AsterCrash,
Thank you for your update and for clarifying that the issue occurs consistently in Need for Speed Heat and only with this specific title. I also appreciate the detail that your graphics settings are currently set to High (previously Ultra). This helps narrow down the scope of the problem.
To move forward with a more precise analysis, could you kindly provide the following details I mentioned earlier:
  1. Was the game installed via Steam, EA App, or another platform? Also, could you confirm the game version?
  2. When you experience the issue, is it specifically low FPS, stuttering, freezing, or a combination?
These details will help me determine whether this is a game-specific compatibility issue, a driver interaction, or something else entirely.
Von M.
AsterCrash
1. Installed on Steam, the latest version available, I recently installed it.
2. Apart from texture bugs, occasional stuttering.
VonM_Intel
Hello AsterCrash,
Thank you for sharing these details and for providing the screenshot. Stuttering issues have been confirmed while playing Need for Speed Heat* on Intel Arc graphics cards. Users experience noticeable stuttering while traveling across the map, indicating a performance problem specific to these graphics cards.
I noticed in the image that the terrain in the game appears somewhat blurry or smoothed out, which could point to graphical rendering behavior. To help us narrow down the investigation, could you please confirm the exact version of Need for Speed Heat you currently have installed? Also, would you like us to primarily focus on the performance concerns you’ve mentioned, or on the graphical bug issue seen in the screenshot? This will help us prioritize the issue that matters most to you first, and for the other concern, we kindly suggest creating a new thread so it can be addressed more efficiently.
Von M.
AsterCrash
I prefer performance,
the game version is 1.0.60.7040.
VonM_Intel
Hello AsterCrash,
Thank you for confirming your game version (1.0.60.7040) and for sharing your preference regarding performance. We’d like to let you know that performance issues with Need for Speed Heat on Intel Arc graphics cards are currently under investigation. Specifically, there are known stuttering problems when traveling across the map, as well as launch issues caused by the game’s error message system incorrectly detecting the driver as outdated. These issues have already been identified, and we’re continuing to look into them.
In the meantime, I’ll be conducting further research into this and will post an update in this thread as soon as I have more information to share.
Von M.
VonM_Intel
Hello AsterCrash,
Thank you for your patience. After reviewing your case, I recommend updating to the latest Intel® Graphics Driver version 32.0.101.8135. Please perform a clean installation using DDU (Display Driver Uninstaller) to completely remove any remnants of previous drivers or applications before installing the new version.
Once the installation is complete, kindly check if the issue persists and let us know the outcome so we can assist you further.
Von M.
AsterCrash
I still have the same problem, I didn't mention it before, but even in the menu it keeps freezing the cutscene and even the audio keeps freezing like a scratched CD.
VonM_Intel
Hello AsterCrash,
Thank you for sharing these additional details. I’ll need to conduct some further research on this issue to ensure we provide you with the most accurate guidance. Once I have more information, I’ll post an update here in the thread. I really appreciate your patience in the meantime.
Von M.
VonM_Intel
Hello AsterCrash,
Thank you for your patience while we looked into this. I’ve sent you an email with further information, as it includes some confidential details that are best shared privately.
Von M.
VonM_Intel
Hello AsterCrash,
Thank you for your patience while we looked into this. Based on my further investigation and research, please note the following points regarding the stuttering observed:
  • Some stuttering may occur the first time you pass through a new area or participate in a race, which is normal. After that initial pass, no further stuttering should occur. Optimizations have been made to improve stability and performance during extended gameplay sessions.
  • Performing a clean driver installation may temporarily bring back the issue, as it clears previously cached shaders.
  • If you experience consistent stuttering across multiple runs (not just during the first pass), please reach out to Intel Customer Support for further assistance.
I hope this helps clarify the behavior you’ve been seeing. Please let me know if you have any additional feedback so I can check it.
Thank you again for your time and cooperation.
Von M.
VonM_Intel
Hello AsterCrash,
Von M.
VonM_Intel
Hello AsterCrash,
I have not heard back from you, so I will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Von M.
