Intel® Arc™ Discrete Graphics
3585 Discussions
terrible performance in the game Path of Exile 1
afsdsome
   Hi everyone! After buying it, I ran into performance issues and constant crashes in my favorite game, Path of Exile.
    On Vulkan, you can only play for a few seconds on maps—almost immediately there's an error and the game closes without any error message, it just shuts down.
    On DX12, performance in the city immediately drops by 30-40 percent, crashes are less frequent, but it still constantly and randomly kicks me out, mostly during location loading. I don’t even want to talk about DX11, the performance there is at the level of my old GTS 450...
     My configuration is as follows:
CPU: AMD Ryzen 5 5600X
GPU: ASRock Arc B580 Challenger 12GB OC
RAM: Corsair Vengeance LPX 32GB Kit, DDR4-3600
SSD: fanxiang 512GB NVMe SSD, PCIe Gen3, 3200MB/s
Win 11 ver. 25H2
     The latest version of the driver is installed (it is also worth noting that it is impossible to install the drivers without getting 'Error 1')
  For a clear example, I will add two gameplay videos. I also want to note the unpleasant flickering of the monitor in busy scenes, as if the screen turns off for a millisecond.
1. https://youtu.be/x4PPYGSLREc?si=2SyyCWclnI1DAPaX  In the first video, a simple map is running, which, in theory, should give at least 100 FPS (I would be fine with 60).
2. https://youtu.be/LhcuEK7-2XY?si=cmGkvnuAJOpUyGxt   In the second video, a classic high-level map is running, not heavy and not light in terms of load. But here, there are already steady 5-10 FPS in groups of monsters.
    I would also like to note the large number of performance complaints on the game's own forum; I can provide links upon request.
     I would be very grateful for a response, thank you
RiL83
Bumping this thread, the only way to have smooth gameplay in POE 1 is to use Vulcan, Vulcan is stable for about 10-20 min after a fresh install of Intel drivers, after that it crashes, it constantly crashes.  So focus on getting Vulcan API to work please, there are many many threads on this issue in POE support forums.  The crashes does not throw any error mgs but win event viewer has a bit of more info at least.
Im using a B570, 16GB Ram and 5700X3D CPU, smooth sailing in other games as long as im not at max sailing. Resolution is 3440*1440.
I need a confirm from Intel that they will look into this issue soonest, if not I need to return my B570 and find another GPU.
Event viewer error: (I did try using older driver as well so that is included): 3 events below, same error code for both driver versions.
- EventData
AppName PathOfExile.exe
AppVersion 0.0.0.0
AppTimeStamp 69098694
ModuleName igc64.dll
ModuleVersion 32.0.101.6733
ModuleTimeStamp 67ed77d9
ExceptionCode c0000005
FaultingOffset 00000000011ebdbb
ProcessId 0x4dd0
ProcessCreationTime 0x1dc4e33fdd4e550
AppPath C:\Program Files (x86)\Grinding Gear Games\Path of Exile\PathOfExile.exe
ModulePath C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_9633261779bf071d\igc64.dll
IntegratorReportId 736de448-49ad-4764-8211-fda3d82c7746
PackageFullName
PackageRelativeAppId
AppVersion 0.0.0.0
ModuleVersion 32.0.101.8247
ModuleTimeStamp 68f8b8ae
FaultingOffset 000000000129643b
ProcessId 0x2d00
ProcessCreationTime 0x1dc4e363c0416f0
ModulePath C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_c9d58d8afce303a5\igc64.dll
IntegratorReportId 4bde9c63-4ec3-41c9-9408-101fe476a791
PackageFullName
EventData
AppVersion 0.0.0.0
ProcessId 0x26a8
ProcessCreationTime 0x1dc4e36ac4b0bd4
IntegratorReportId 8ba92efa-16ce-4420-a8a9-56ab664a3eb9
PackageFullName
RiL83
I saw a new driver was available today, tried it, same issue as before using vulkan, did some more testing since one of the threads here recommended an older driver so did some uninstalling with DDU and installed that fancy old thing, well, same....
Below is events for driver 8250 and for 6647, Intel fix this asap or i need to install my old card or get an navidia one.
EventData
AppVersion 0.0.0.0
AppTimeStamp 691530b7
ModuleVersion 32.0.101.8250
ModuleTimeStamp 690e3b93
FaultingOffset 00000000012963fb
ProcessId 0xd9c
ProcessCreationTime 0x1dc57321d205057
ModulePath C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_04d65f21e92ccd2d\igc64.dll
IntegratorReportId 17fd7310-d71a-4b0c-9f2c-a24d622db37c
PackageFullName
EventData
AppVersion 0.0.0.0
ModuleVersion 32.0.101.6647
ModuleTimeStamp 67c1f47d
FaultingOffset 00000000011d882b
ProcessId 0x3c90
ProcessCreationTime 0x1dc573607294266
ModulePath C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_eeea066e03c15baf\igc64.dll
IntegratorReportId 496848d1-472d-4cbb-842e-acb04bfa0e76
PackageFullName
RiL83
I recommend that you try the old driver 32.0.101.6647, vulkan still crashes as i reported but i do see a performance increase in DX 12 using this one, now the game does not look like Megaman on NES when running.  You will not get 100+ FPS that Vulkan provides but i do see that i dont drop below 40 when doing the breaches.
DeancR_Intel
Hi afsdsome,
Thank you for the detailed report about the Path of Exile performance and stability issues with your Intel Arc B580 Challenger. I understand how challenging it must be dealing with constant crashes and severe performance drops, especially when you're unable to enjoy your favorite game properly.
The gameplay videos clearly demonstrate the performance issues you're experiencing, from the low FPS on simple maps to the 5-10 FPS drops during monster encounters.
To help investigate this comprehensively, please provide the following diagnostic information:
Event Viewer Logs:
This information will help us identify whether this is a driver compatibility issue, game-specific optimization problem, or hardware-related concern.
Hi RiL83,
Thank you for the additional Event Viewer logs showing igc64.dll crashes across multiple driver versions with your B570.
To ensure you receive focused support and avoid confusion in this thread, please create a separate support thread for your B570 issue. This will allow us to provide targeted assistance for your specific hardware configuration.
Dean R.
afsdsome
Hi, thanks for the reply. Here are the necessary files, I hope I did everything correctly.
oWolkodaWo
Good afternoon, I have an Intel Arc B580 Maxsun iCraft on hand and I have similar problems. I tried to install old drivers, the situation is changing just a little bit, I want to fix Vulkan, everything worked stably on it
MichaelMc
I’d recommend closing all background apps before running the Intel System Support Utility. It helps make the report cleaner and gives a more accurate picture of what’s happening with your drivers. Running it with unnecessary programs open can sometimes hide conflicts or make the logs harder to interpret, so this little step can save time when troubleshooting.
KoN
Try driver 8247. Run DDU and clean installation.
I'm on the latest driver 8250, and I'm getting bad stuttering in games. Card is going from 50% - to 70% up and down, not stable .
MichaelMc
It looks like the issues are mostly tied to the Arc drivers. I’d recommend completely uninstalling your current driver using Display Driver Uninstaller (DDU) and then doing a clean install of an older version, like 6647 or 8247. A lot of users have reported that this helps reduce crashes and improves stability in DX12. It’s also worth making sure no other driver remnants are left behind, and sometimes running the installation offline can prevent unexpected errors. This approach won’t fix Vulkan crashes completely, but it usually makes the game playable for longer sessions.
RiL83
I have tried 8247 and Vulkan is unplayable on that one as well. DDU used for all driver changes and removing remnants from Nvidia
DeancR_Intel
Hi afsdsome,
Thank you for providing the diagnostic files! I appreciate you taking the time to gather the Event Viewer logs and Intel SSU report - this will be very helpful for analyzing the Path of Exile performance and stability issues you're experiencing.
Before I dive into the analysis of your files, I have one additional question:
Have you tried using DDU (Display Driver Uninstaller) to perform a clean removal and reinstallation of your Intel Arc graphics drivers? See link for the steps: How to Use the Display Driver Uninstaller (DDU) to Uninstall a...
DDU can help eliminate any potential driver conflicts or corrupted installations that might be contributing to the crashes and performance issues you're seeing in Path of Exile.
If you haven't tried DDU yet, I can provide guidance on the proper procedure. If you have already used DDU, please let me know so I can focus the analysis on other potential causes.
Dean R. Intel Customer Support Technician
afsdsome
Hey
Yeah, I tried installing the drivers according to the instructions… but that's also where I ran into the problem that the official software program wouldn't install. The drivers, however, installed without any errors, so right now I’m without the utility but with successfully installed drivers
***Usually, when I tried to install the drivers in normal Windows mode, I got error "1" every time, but at least I had the software. In safe mode, I could install the driver itself without errors, but then the Intel application for game settings wouldn’t install
DeancR_Intel
Hi afsdsome,
Thank you for trying the DDU procedure and providing that update. I understand the installation challenges you're experiencing - it's good that the drivers installed successfully in safe mode, even though you're missing the Intel Graphics Software utility.
Regarding your installation issues:
Since you have the drivers working but missing the utility, you can try downloading and installing just the Intel Graphics Software separately. Sometimes installing the utility after the drivers are already in place can resolve the installation conflicts.
The fact that your drivers installed successfully in safe mode without errors means you have the core functionality. The utility is helpful for game optimizations and settings, but not essential for basic operation.
This is often related to antivirus interference or Windows security features. Since safe mode worked, this confirms it's likely a software conflict rather than a hardware issue.
Now that you have working drivers, could you test Path of Exile again and let me know if the performance and stability issues persist? This will help me determine if the problems were driver-related or if we need to investigate other causes.
Dean R.
afsdsome
Hi, I probably should have mentioned right away that the drivers were installed in safe mode, and then the game was tested. To repeat— the game still freezes, has very low performance, and on Vulkan there are constant crashes to the desktop. On DX12 it crashes less often, but the performance is also worse, apparently by 40-60 percent. The problem is still relevant
KoN
I would try an older driver . Boot into safe mode and use DDU , then install older driver , use clean install from intel .
Thats all i can say really . i will try a vulkan game star citizen see if it crashes . i rolled back to 8247 drivers .
afsdsome
Hi, to address your question about a specific game, it's better to create a separate thread right away.
afsdsome
Up.
There are also constant crashes in games like Cyberpunk, Divinity 2, Expedition 33... also for no apparent reason at random points between 5 to 20 minutes of gameplay - it's impossible to play, completing even a single mission that takes 5-10 minutes becomes unrealistic, since you have to replay it 5 times. Unfortunately, it's really discouraging, and I would like to change the graphics card... waiting 4-6 weeks for a solution is another challenge... we are waiting for some kind of resolution.
afsdsome
Crash logs from Cyberpunk
maybe this will help somehow. or you'll give advice on the graphics card
DeancR_Intel
Hi afsdsome,
Thank you for the additional testing and crash logs from Cyberpunk 2077. I understand how discouraging it must be to experience these widespread crashes across multiple games (Path of Exile, Cyberpunk, Divinity 2, Expedition 33) making it nearly impossible to complete even short missions.
The fact that crashes occur randomly between 5-20 minutes across different games suggests a broader stability issue that we need to address systematically.
I'd like you to try the latest driver version 32.0.101.8250 which may resolve these stability issues:
Download: https://www.intel.com/content/www/us/en/download/785597/intel-arc-graphics-windows.html
Test the same games and monitor for crash frequency. Please let me know the results after testing with the 8250 drivers.
Dean R.
afsdsome
no changes for now, still 5 minutes and a crash
