Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
AMT: Unspecified Event Codes (POST Error)
Stas_Z_
I have 2 motherboards (from 25), which log unknown error some times. I didn't find the description of it in various documents ("Alert Standard Format (ASF) Specification, ver. 2.0", "IPMI PET to Platform Message Registry Mapping, ver. 1.2.0", "IPMI Platform Event Trap Format Specification, ver. 1.0", "IPMI  Specification Second Generation, ver. 2.0", WSEventAndPetTableReplacement.xls).
Motherboard: DQ965GF
EventSensorType:Fh (POST Progress/Error)
EventType:6Fh
EventOffset:0h
Severity: Non-recoverable
Event Data: 40 14 00 00 00 00 00 00
Entity: 26 (Other chassis board)
Can anyone give me explanation of what happens with these two m/boards and there I can get the list of Platform Event Codes.
Thanx!
Gael_H_Intel
What version of AMT is this? I assume you have gone through the SDK docs? http://software.intel.com/sites/manageability/AMT_Implementation_and_Reference_Guide/DOCS/Implementation%20and%20Reference%20Guide/default.htm?turl=WordDocuments%2Fwseventingeventfields.htm It kind of sounds like this is not a PET event sent by AMT. It could be OEM specific, too. Is there any more information you can pass on? Also here are some more links that may or may not help: http://software.intel.com/en-us/blogs/2008/03/06/what-about-those-pet-events http://software.intel.com/en-us/blogs/2007/09/18/more-technology-distinctions-intel-amt-vs-asf-part-3/
Stas_Z_
AMT Hardware Asset (Baseboard): Manufacturer: 'Intel Corporation' Product: 'DQ965GF' Version: 'AAD41676-601' Asset tag: 'Base Board Asset Tag' --------------------------------------------------------------------- AMT General Info: AMT version: 2.2.20 Code Versions: Flash: 2.2.20 Netstack: 2.2.20 AMTApps: 2.2.20 AMT: 2.2.20 Sku: AMT + ASF + QST SKU VendorID: 8086 Build Number: 1041 Recovery Version: 2.2.20 Recovery Build Num: 1041 Legacy Mode: False BIOS version: CO96510J.86A.6100.2009.1004.2331 Provisioning mode: SmallBusiness Provisioning state: Post Provisioning Config Server (IP:port): 0:9971 VLan: Disabled Network State: Enabled Enabled Interfaces: WebUI, SerialOverLAN, IdeRedirect Password model: Separate Local 'admin' password: changed from default Remote 'admin' password: changed from default Security parameters: Enterprise Mode: False TLS Enabled: False HwCrypto Enabled: True Provisioning State: Post Provisioning Network Interface Enabled: True SOL Enabled: True IDER Enabled: True FWUpdate Enabled: True Link Is Up: True
