Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
1406 Discussions
How to use 'ReflashBios' feature of AMT to update the BIOS of Intel m/boards?
Stas_Z_
I have two Intel desktop boards with AMT: DQ965GF and DQ57TM and use SOAP-based access to the AMT features.
"Network Interface Guide" states, that 'RemoteControl' can be used to PowerUp/Reset the machine with 'ReflashBios' bit set. Description of 'ReflashBios' from the doc: "the boot block reflashes the BIOS on the next boot, using IDE redirection as the source of the BIOS image".
'GetRemoteControlCapabilities' returns ENABLED BiosReflash in OemDefinedCapabilities for the both m/boards.
I can't find the procedure of the BIOS update. "The boot block reflashes...": what is the boot block mentioned?. I tried to setup IDER-CD (with ISO-image, containing BIO-file from the motherboard downloads area) and powerUp by AMT with ReflashBios set. Nothing's happened.
I also tried to enter to the bios update by F7 with IDER-CD set; redirected CD drive doesn't listed in the possible sources of BIOS image (like as any hardware CD/DVD).
Gael_H_Intel
Hi - I wanted you to know that I have seen this question but I'm going to have to do some research on it. Sorry for the delay.
