Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
1409 Discussions
ByPass the BIOS password from Linux management to Window system
Nguyễn_Văn_Q_
>Hi all.
I want to describe information about my application on Linux management:
Purpose: I want to bypass the BIOS password from Linux system to Window system. Following functional:
 1. Check power State of vPro system:
     + Reference url (https://software.intel.com/sites/manageability/AMT_Implementation_and_Reference_Guide/default.htm?turl=WordDocuments%2Fgetsystempowerstate.htm)
     + I have implemented' CIM_AssociatedPowerManagementService.PowerState' object to get powerState of vPro system.
2. Change powerState (PowerOn) vPro system:
     + Reference url       (https://software.intel.com/sites/manageability/AMT_Implementation_and_Reference_Guide/WordDocuments/changesystempowerstate.htm)
     + Retrieve the instance of Cim_PowerManagementService and call this method Cim_PowerManagementService.RequestPowerStateChange with  following parameters:
  • powerState: One of the defined power states
  • Managed Element: A reference to the "managed system" object
  • Time: NULL
  • TimeoutPeriod: NULL
3. Problem:
   + Currently, the state of the option [PowerOn password] in vPro BIOS configuration must be "ON" (required).
   + When vPro is turned on, it requires user to input [PowerOn password] and i have to input the password manually. So my question here is:
   - Can I set the [PowerOn password] in the PowerManagementService object so when i use my application to turn on vPro, it will bypass the input [PowerOn password] screen and instantly move to the log in screen of the OS ? Is there any other way to bypass this input [PowerOn password] screen ?
Thank you for your help.
Nguyễn_Văn_Q_
Hi all,
Anyone, Please help me resolve this issue !
Cheers
