Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
1407 Discussions
Can't connect to AMT processor with computer powered off
red888
I configured AMT on a dell 780 and using the "manageability commander tool" and can connect with the PC powered on, but when its off I can't connect. I can see the NIC lights blinking when its powered off, I also made sure that wake on LAN is enabled (if that is evennecessary).
Thanks for any help.
RBens2
Valued Contributor I
Hi Red888,
You've got to check the power policy that the system is set to work under. To be able to connect in one of the low power states, the power policy has to be set to "ME powered on in S3, S4, and S5 on AC with ME/WOL" (or something like it). The default power policy probably turns the ME off in the Sx states, so you can't connect to the ME. Also, host WOL has nothing to do with ME WOL, so don't think that because you've turned on WOL, that you can connect to the ME in the Sx states; you have to select the correct power policy.
Roger
red888
Cool thanks i couldn't find that info anywhere easily.
Gael_H_Intel
When you boot your system, you should see a prompt to enter CTRL-P - doing so will take you into the ME Bios Extenstions menu. You can specify your desired power settings in those menus.
You should also be able to do this using the Web UI when the system is up. (http://:16992)
There are some basic settings in the Web UI that will allow you to change them as well.
If you do not see a prompt to enter CTRL-P while booting, it may be disabled in the BIOS - boot to BIOS and look for your MEBX options and make sure they are enabled. Some OEMs also don't use the CTRL-P, but instead have the MEBx settings inside their BIOS interfaces.
Which system are you experiencing this problem with?
