Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
one question about network filter
ahju
hello, I have a question about network filter.
I used the RDK commonder to create a IP filter, i had selected a direction , i found the "TCP/IPV4 Packet Filter" below, i had to select a direction again and input a IP Address and mask. what is the relationship between the two directionthat i input, andwhat is the meanningof the IP Address which i input.
thanks.
Gael_H_Intel
There is a nice description of how the System Defense filters work in the AMT SDK Documentation - you can read about them online here.
Look under Intel AMT Features/System Defense/Detailed Descriptions. There is a section that identifies what the filter types are and what they do.
Let us know if this helps.
Gael
ahju
Hello, thanks for your reply.
Maybe I didn't discribe my question clearly, and forgive my poor english.
I had read the AMT SDK Documentation online, and I found that the struct of the Filter supplyed online doesn't the very like the struct supplyed by the SDK samples. for example, I create a filter like the following.
name = IPFilter;
FilterProfile = 0;
FilterDirection = 0;
ActionEventOnMatch = 0;
HdrIPVersion = 0;
after I input all this parameters, I had to input a specifed Ip Address and mask and the direction. Through it doesn't had to, but I can not understand what is the specifed Ip address means? Is it only in AMT SDK 3.0?
Do I describe it clearly? I don't know post a picture to this forum, or I can describe it more clearly.
Andrew_S_Intel2
Hmm, maybe the best way to proceed is to go with a simple example. Could you give a simple example of the behavior are you trying to get AMT perform? Block all traffic? Allow traffic to a certain IP range? If I know that, I think I can give you an example of the AMT_*Filter and associated AMT_SystemDefensePolicy you'd need to create to have that behavior (assuming, of course, that it's possible)
Andy
ahju
Thanks for replying.
Maybe I haven describe my question clearly. Can I have your email address, I can email you, and describe more detail about my question.
duofeng-li
ahju, I have tried to answer your question in Chinese forum. http://software.intel.com/zh-cn/forums/showthread.php?t=78732
ELAN_TECHNOLOGIES
Thanks ahju for this Question, I was suffering the same problem from past 2 days..I Google'd it too but couldn't found it...satisfied Now..
