Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
Difficulty with AMT SDK. 401 unauthorized response
inbrian
So far I have not had any luck with the AMT SDK and the AMT machine I have been testing with. I have tried both the included samples as well as code that I have written.
Running the GeneralInfo.exe example, I get the following output:
Calling function GetCoreVersion...
Error: failed while calling GetCoreVersion
SOAP failure: error code = 25
What I see when I sniff the traffic between the machines is the same for both my code and the sample code. The software makes a HTTP POST/SOAP request to the AMT machine. The AMT machine responds with a "401 unauthorized" response. The response includes an nonce value. I'm thinking that the AMT management software should be making another request to the server using digest authentication. However, this does not seem to be happening.
What am I missing here?
Lance_A_Intel
How did you configure AMT on your client?
If you are new to AMT please take a look at this Start Here Guide which includes steps for initial configuration.
inbrian
I have a pretty unusual setup here I'm working with. I was hoping I just overlooked something simple. Maybe I can find another machine that I can change the settings on to be more like a typical setup. Thanks for your help.
Lance_A_Intel
Taking a look at a simple setup is a good idea.
Let us know if you have more trouble.
inbrian
It turns out there were a couple issues. One of which is that I had the incorrect password for the machine. Thanks again for the help!
Lance_A_Intel
Quoting - inbrian
No problem, glad you have it working :)
