Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
Edit Client's BIOS remotely - Intel AMT 1.0
sawguan
Hi all,
I am currently trying to edit some BIOS configuration remotely via my server which runs on Windows Server 2003 and using LANDesk Management Suite 8.7 (trial only).
Any methods for me to perform this using LANDesk or there are specific tools needed for this?
*Extra Note: My client is a 945GM supporting Intel AMT 1.0 only.
SawGuan
Gael_H_Intel
Normally Serial-Over-Lan activities are accomplished in conjunction with the IMRGUI tool that is part of the SDK (it is in the bin folder.) There are also documents that further discuss SOL and IDE-R in the docs folder.
--GTH
sawguan
Thanks GTH.
As what you replied, i need an Intel AMT SDK in order to use the IMRGUI.exe tool (hope i got this right). I tried to search all over the internet but i only managed to find AMT v2 related stuff and not v1.
That's sad.
SawGuan
Gael_H_Intel
Since I am not familiar with the capabilities of the Landesk Management Suite, you may want to see if this tool provides that capability with AMT 1.0 systems. Unforntunately, I do not have much experience with AMT 1.0 capabilities but maybe someone else on this forum does and could offer some advice.
GTH
sawguan
Thanks for spendingyour time to reply.
ylianst
Hi there,
The IAMT 2.0 SDK (and the soon to be released 2.1 SDK) should work ok with IAMT 1.0 machines. Of course, there are more features in 2.0, but the documentation will tell you which calls are IAMT 2.0 specific. My main development machine is IAMT 1.0 and I have used the latest SDK to do Serial-over-LAN with it.
Ylian
Intel Software Engineer
Jia-Shing_W_Intel
Using SOL to remotely control a system is supported by most if not all current ISV applications claiming AMT support. AMT SDK provides backward compatibility support, so if an ISV software claims it supports AMT2, then it should work on AMT1 systems as well. Of course, new AMT2 features are available only AMT2 systems. LANDesk Management Suite user's manul should be able to tell you how this can be done.
sawguan
Hi guys,
Did you alluse LANDeskto remote control an iAMT enable client during out-of-band mode (eg: Editing BIOS)? I tried out using AMT SDK and it works but i'm wondering whether LANDesk supports this or not.
SawGuan
Gael_H_Intel
You would need to look at the LANDesk documentation and see if it is adverstised to work. If it is supposed to do this, but doesn't you would need to contact LANDesk. We willbe posting a utility to the Manageability site early in 2007 that you could use to check to see if features work or not and since it is our product you will also be able to communicate with us directly if you think there are problems with it.
GTH
sawguan
Hi jwang34,
I saw the statement saying that AMT SDK provides backward compatibily support as well. But when I tested it out on my platform (945), therewere few errors shown. One of themwas SOAP error.
SawGuan
Steven_W_Intel
SawGuan,
Can you please respond with the errors you are receiving and which (945) system are you using? Awaiting your reply.
Steve Williams
sawguan
Steve,
The error reported sounds like this:
"SOAP failure : error code = 22"
there is another error when i try to Open SOL session:
"SOL was not found in the AMT capabilities list and is unavailable"
SawGuan
Jia-Shing_W_Intel
SawGuan,
What 945 system are you using, from what vendor and what is the model number? Did you always have this problem or did it only happen occassionally? When would you see this SOAP failure with error code 22? Your answer can help us root cause the problem and solve your issue.
Jia-Shing
sawguan
Hi Jia-Shing,
I'm using 945GM, its actually customizedboard from a vendor. But it is not much different if compared to Calistoga. The SOAP failure error code 22 occurs everytime when i invokesome samples from Intel AMT Release 2.0.
SawGuan
Jia-Shing_W_Intel
Hi SawGuan,
You are using Napa systems, sorry I didn't realize that earlier. I haven't personally played with any of those but I believe the basic idea is the same. At boot up, did you hit [Ctrl] +
to enter BIOS extension screen and then change password and configure all the settings? SOAP failure error code 22 means the authentication doesn't go through. If you are running the samples in SDK, did you use "-pass" argument to provide a password, a strong one? Try to use a browser to connect to your AMT system and see if it works, http://your_ip_address:16992/. I hope this helps.
Jia-Shing
sawguan
Hi Jia-Shing,
Yes, during boot up i hit [CTRL] +
to enter AMT BIOS. I changed my password (a strong one) and i change the address as well. I tried using my web browser to connect to http://my_ip_address:16992 and it works. But the SOAP failure error code 22 still exist.
SawGuan
Gael_H_Intel
When you enter your command you may need to also enter -user admin -pass
Whenever I get that error it is because I have forgotten to enter the -pass and -user command options.
GTH
