Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
Error executing CircuitBreaker Sample
alberto_sagan
Hi all,
I have tried to execute CircuitBreaker sample but I have received an error message.
I am using SDK 5.0, Intel AMT 3.0.
When I launch: ./circuitBreaker http://hostname:16992/CircuitBreakerService -user admin -pass XXXXXX
The messages I get is:
"Calling function CbQueryCapabilities.....Success
Calling function CbFilterCreate....
Error: failed while calling CbFilterCreate
Status = 36"
What is it happenning? I have launched AssetDisplay sample and I have no problem with that sample, but with this...I dont know what else to do.
Anyone can help me?
Thanks a lot
Andrew_S_Intel2
According to the network interface guide (on page 390), code 36 is:
PT_STATUS_INVALID_PARAMETER = 0x24
It's interesting that queryCapabilities succeeded and createFilter failed, that seems to rule out problems with connecting to the AMT device properly. Can you try this command again and add the -verbose option, and see what kind of feedback you get?
./circuitBreaker http://hostname:16992/CircuitBreakerService -user admin -pass XXXXXX -verbose
Lance_A_Intel
Also, are you running this command locally or from a remote machine?
alberto_sagan
I am running this command remotely.
alberto_sagan
Hi, I have tried every different option (-A,-L,...) and I get the same error messages.
I have translated the display functions, but I have tried to execute the original circuitBreaker and I get the same error I get in the modified version. My mods are only in the language, anything else.
./circuitBreaker http://hostname:16992/CircuitBreakerService -user admin -pass XXXXXXXX -verbose
Capacidades del Circuit Breaker
Numero maximo de politicas soportadas = 8
Numero maximo de filtros soportados = 80
Descripcion Hardware: Wired NIC
Hardware ID: 0
Numero maximo de filtros IPv4 activos en Tx : 28
Numero maximo de contadores IPv4 activos en Tx: 16
Numero maximo de filtros IPv4 activos en Rx: 32
Numero maximo de contadores IPv4 activos en Rx: 16
Anti Spoofing IPv4 Activado o No: 1
Numero maximo de filtros IPv6 activos en Tx: 28
Numero maximo de contadores IPv6 activos en Tx: 16
Numero maximo de filtros IPv6 activos en Rx: 32
Numero maximo de contadores IPv6 activos en Rx: 16
Anti Spoofing IPv6 Activado o No: 0
Numero de filtros IPv4 usados por trafico IPc6: 1
Status = 36
Calling function CbFilterGet...
Error: failed while calling CbFilterGet
Status = 2053
Calling function CbFilterDelete...
FilterCreationHandle = 27
Error: failed while calling CbFilterDelete
Status = 2053 "
Can anyone help me?
Thanks a lot again
Lance_A_Intel
Would you please run the Commander from the DTK and check if there are any pre-existing filters. You may have met the limit to the number of filters or there may be a conflict with an existing filter.
You may also want to try upgrading to latest AMT firmware version (check with you OEM to get this).
alberto_sagan
I have executed Commander and there are only 7 filters and there are no new configuration, so It isnt the problem.
Anyone else can help me?
Thansk a lot
alberto_sagan
Quoting - alberto_sagan
Hi all,
Status = 36"
Anyone can help me?
Thanks a lot
Please...I have no answers for this problem!!!
Can anyone help me?
Thanks a lot
Sreelekshm_S_Intel
We are working on this; will get back to you soon.
Sree
Lance_A_Intel
We have not been able to reproduce your error on our systems. The sample works fine on all the configiurations we have tried.
Do you have another system you can test on? Or can you unprovision this system and start fresh on it?
Also, as mentioned before, you should try to upgrade to the latest firmware for your system.
