Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
Error to initialize SOL. Error 1
adrianfreemantle
Im busy writing an application to do AMT SOL, however i seem to be getting the following error sometimes and it does not seem to be orriginating from my code: "Error to initialize SOL. Error 1"
Does any one know what this means or where the error may be comming from?
Adrian.
ylianst
I have built an SOL application and have not seen this. Have you been able to use SOL before with a different application?It's possible that the SOL/IDE-R port is closed and so, the connection is rejected. I will have to go check if I can find that error code.
Ylian
Gael_H_Intel
Are you saying that sometimes it works and other times it doesn't work? If you haven't been able to connect at all, please check that you have enabled SOL/IDE-Rin the BIOs and AMT configuration setting (BIOS/MEBx settings.)
GTH
Gael_H_Intel
You also might want to check out section 1.3 of the Redirection Library User Guide.pdf - this section provides and overview of SOL/IDE-R and explains how to enable them (if you haven't already tried this.)
GHolmes
