Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
Error when compiling SDK kit
sysadmin
Iam  attempting to compile the sdk kit for the Vpro/AMT technology. I downloaded intel_amt_ release_3.0.2 _gold_sdk_hotfix.zip, however when trying to compile i am getting the following errors, any assistance would be greatly appreciated.
[root@crm-dev Src]# make
rm -f *.scc */*.scc */*/*.scc */*/*/*.scc
cd StorageLib && make clean
make[1]: Entering directory `/root/intel/Src/StorageLib'
cd LIBCODE && make clean
make[2]: Entering directory `/root/intel/Src/StorageLib/LIBCODE'
rm -f ../../../ThirdParty/gSOAP/stdsoap2.o ../../../ThirdParty/gSOAP/httpDigest.o ../../../ThirdParty/gSOAP/digcalc.o envC.o STORAGEC.o STORAGEClient.o iamt_api.o iamt_buf.o iamt_hash_linux.o iamt_os_linux.o BiosParser.o PhysMemAccess.o rijndael-api-fst.o rijndael-alg-fst.o ConvertUTF.o *~ *.xml *.nsmap soap* envC* envH* envS* STORAGE* StorageInterface.h
make[2]: Leaving directory `/root/intel/Src/StorageLib/LIBCODE'
cd Install && make clean
make[2]: Entering directory `/root/intel/Src/StorageLib/Install'
rm -f PhysMemAccess.o BiosParser.o BiosParserMain.o
rm -rf .libs
rm -f biosParserRH4*
make[2]: Leaving directory `/root/intel/Src/StorageLib/Install'
rm -f
rm -rf biosParser/
rm -f INSTALL
make[1]: Leaving directory `/root/intel/Src/StorageLib'
rm -rf .libs
rm -f
rm -rf biosParser/
rm -f INSTALL
cd LIBCODE && make
./../../ThirdParty/gSOAP/wsdl2h -e -y -t ../../../ThirdParty/gSOAP/typemap.dat -o StorageInterface.h -n storage ../../../Include/WSDL/StorageInterface.wsdl
** The gSOAP WSDL parser for C and C++ 1.2.8c
** Copyright (C) 2000-2006 Robert van Engelen, Genivia Inc.
** All Rights Reserved. This product is provided "as is", without any warranty.
** The gSOAP WSDL parser is released under one of the following two licenses:
** GPL or the commercial license by Genivia Inc. Use option -l for more info.
Saving StorageInterface.h
Reading type map file '../../../ThirdParty/gSOAP/typemap.dat'
Reading file '../../../Include/WSDL/StorageInterface. wsdl'
To complete the process, compile with:
soapcpp2 StorageInterface.h
echo namespace STORAGE { > StorageInterface1.h
cat StorageInterface.h >> StorageInterface1.h
echo }// namespace STORAGE >> StorageInterface1.h
rm -f StorageInterface.h
mv StorageInterface1.h StorageInterface.h
./../../ThirdParty/gSOAP/soapcpp2 -x -C -w -I../../../ThirdParty/gSOAP -pstorage -n StorageInterface.h
** The gSOAP Stub and Skeleton Compiler for C and C++ 2.7.8c
** Copyright (C) 2000-2006, Robert van Engelen, Genivia Inc.
** The gSOAP compiler is released under one of the following three licenses:
** GPL, the gSOAP public license, or the commercial license by Genivia Inc.
Using code namespace: STORAGE
Saving STORAGEStub.h
Saving STORAGEH.h
Saving STORAGEC.cpp
Saving STORAGEClient.cpp
Saving STORAGEClientLib.cpp
Using storage1 service name: StorageSoapBinding
Using storage1 service style: document
Using storage1 service encoding: literal
Using storage1 service location: http://hostname:16992/StorageService
Using storage1 schema namespace: http://schemas.intel.com/platform/client/Storage/2004/01
Saving STORAGEStorageSoapBindingProxy.h client proxy
Saving STORAGE.nsmap namespace mapping table
Compilation successful
touch env.h
./../../ThirdParty/gSOAP/soapcpp2 -x -C -w -I../../../ThirdParty/gSOAP -penv env.h
Saving envStub.h
Saving envH.h
Saving envC.cpp
Saving envClient.cpp
Saving envClientLib.cpp
rm -f env.h
g++ -Dlinux -DWITH_OPENSSL -DNDEBUG -Wall -Wno-deprecated -Wno-unused -Wno-missing-braces -DWITH_NONAMESPACES -I../../../ThirdParty/gSOAP -I../../../Include -c ../../../ThirdParty/gSOAP/stdsoap2.cpp -o ../../../ThirdParty/gSOAP/stdsoap2.o
./../../ThirdParty/gSOAP/stdsoap2.cpp: In function int tcp_connect(soap*, const char*, const char*, int):
./../../ThirdParty/gSOAP/stdsoap2.cpp:3761: error: invalid conversion from unsigned char** to const unsigned char**
make[2]: *** [../../../ThirdParty/gSOAP/stdsoap2.o] Error 1
make[1]: *** [all] Error 2
make: *** [all] Error 2
Sreelekshm_S_Intel
Which version of SDK are you using? Also, which Linux OS? The User Guide included in the SDK (in Docs folder) gives you details on hardware and software requirements of the system andinstructions for building the SDK. Make sure you have followed those guidelines and have included Third Party, Src, Samples and Lib folders in the same structure as Intel AMT SDK. Let us know how it goes.
Sree
