Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
Help on Intel AMT Outpost
ravi
When i am using Intel AMT Outpost on Intel AMT System by giving
user name , password i got the following error
"Local connection to Intel AMT failed. Check that this computer support,
drivers & password.
Whether i have Install any Drivers in Intel AMT System., if i t require please
provide me the link and provider name to down load and install.
Any Help on this would be appreciated.
Thanks & Regards,
Ravi
Gael_H_Intel
When you set up your AMT system, did you give the ME a strong password? Please verify that you can get to the AMT Login from your Management Console by accessing the following url: http::16992
THE AMT Client is associated with user "admin" along with a strong password (mandatory.)
If you need to load drivers and update firmware, those should have come with your system (on a CD) and you should be able to download all required BIOs/Firmware/Drivers from your OEM's support site.
Hope this helps,
Gael
