Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
IAmtTerm.exe
raul_sanchez
We publish our platform for example in directory C:Documents and SettingsAdministradorConfiguracin localApps2.03T3XXMXZ.T67AANV7KO8.LQ3iris..tion_14401e6ba0f9b9b1_0004.0006_b89d62328bf13217, and in this directory the application IamtTerm that we attach doesnt work, and in other places it works perfectly.
We need this application works in directories like these.
Thanks in advance.
Best regards.
Ajith_I_Intel
Hi Raul,
Thanks for the question. We are looking into this issue and hope to get back to you soon.
Ylian_S_Intel
I just tried running IAmtTerm.exe in the folder you mentionned and it works. I think your problem is a different one, IAmtTerm has dependencies and so, you need these 4 files:
IAmtTerm.exe
IAmtControls.dll
IAmtRemoteStack.dll
imrsdk.dll
If you have these 4 files in the same folder, it would work.
Hope it helps,
Ylian (Intel AMT Blog)
raul_sanchez
I have these 4 files in the same folder... of course. Could you give me the files that you tested?
Ylian_S_Intel
I just used the 4 files out of the latest version of the Intel AMT DTK. It is rather weird that when one of the dependency file is missing, the DTK tools will just show this very bad error message with no clue as to what is going on. Of course, the DTK also relies on Microsoft .NET Framework 2.0, so you must have that installed on that computer.
If the DTK otherwise works on that computer, I think you should play around with it, removing files from the DTK until you have the minimum set. I did try it on my computer and it worked well.
raul_sanchez
What version do you test it?
Ylian_S_Intel
I just tested it using version v0.34, it is now released.
raul_sanchez
If i tested v0.34f in C:APLI+Dbis runksrcIRMServerPlatformsPlatformSmartClientIrmSmartControlWininDebug it doesn't work: i obtain disconnected result, but in others directories it works perfectly. I have the same permissions in all directories i tested... i don't know what is happening...
Gael_H_Intel
Do those other directories have the "+" sign in them? Sometimes I experience problems if my path length is excessively long as well.
raul_sanchez
Exactly with v0.34f (last version i have) the application IAmtTerm.exe has problems with some directories.
I have these directories with the same permissions and IAMTControls.dll, IAMTRemoteStack.dll, imrsdk.dll and IAmtTerm.exe, and the result is:
- For example in C:DTK+2 it works perfectly.
- In C:Documents and SettingsAdministradorConfiguracin localApps2.03T3XXMXZ.T67AANV7KO8.LQ3iris...exe_1df129fea8a2a115_0004.0005_none_e9e0a3f08e736d6b,
we obtain disconnected result.
- In C:APLI+Dbis runksrcIRMServerPlatformsPlatformSmartClientIrmSmartControlWininDebug, we obtain disconnected result, too.
We have integrated this application with our platform and we need it could work with directories like
Best regards
