Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
Intel AMT, VNC and, TLS
Craig_B_
I've recently implemented OOB in my office and I'm having difficulties getting VNC to connect to the clients.  When I try to connect to a client using VNC Viewer Plus I get the following error, "KVM tunnel TLS failure.  Check TLS configuration and certificates."  Everything else is working.  I can connect to the client from IE using HTTPS.  Powershell commands are also connecting to the client using TLS with no issues.  I've pretty much ran out of ideas on how to get this working.  Any help would be appriciated.
MPala11
New Contributor II
Check this link for configuring KVM
https://communities.intel.com/docs/DOC-4795
Cheers,
mani
Craig_B_
Thank you for the reply.  However, this doc doesn't address configuring KVM for use with TLS.  I've successfully configured vnc to work without using TLS, but as soon as I configured the system to use TLS, VNC will error.
Craigster
Gael_H_Intel
Not knowing what your complete network configuration is,  it is difficult to pinpoint any one solution.  Here one blog you might want to see: http://blogs.bamits.com.au/2012/08/how-to-remote-control-vpro-system-on.html
Here is another blog that has some useful information: http://software.intel.com/en-us/blogs/2012/08/08/intel-kvm-port-requirements-and-troubleshooting-tips/?utm_source=feedburner&utm_medium=feed&utm_campaign=Feed%3A+IntelSoftwareNetworkBlog+%28Intel+Developer+Zone+Blog%29
