Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
Intel FPT tool for Linux error 680 and 64
Mschauer
I have a problem with the FPT tool for Linux. I want to disable the Manufacture Mode of the ME.  Unfortunately I get the following error with the command FPT -closemnf NO. also an attempt to flash the BIOS ( FPT -f xx.bin ) brings the same error.
I use the FPT version matching the installed ME version.
Intel (R) Flash Programming Tool Version: 12.0.72.1757
Copyright (C) 2005 - 2021, Intel Corporation. All rights reserved.
Error 680: Read MMIO failed.
Error 64: Failed to initialize SPI interface.
FPT Operation Failed.
I have already tested different Linux versions. Debian 10 kernel 4.19. , Debain 11 kernel 5.10 , Ubuntu 16.4. unfortunately the same problem.
at lspci -vvv i see the driver for HECI Controller is loaded. Kernel modules: mei_me
Basically I have also tested it with a Windows version. There everything worked.
However, I need the Linux environment.
Now the question . what is wrong ?  Bios setting , missing Linux kernel driver ?
trytofix
Did you solve this problem in the end?
I had same issue recently
PatrickHsu
No, I haven't solved the problem yet, did you solved the problem?
I tried testing the tool on Ubuntu 22.04.6 and got the new error
