Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
Intel ME Error during bootup
petis
Débutant
17 410 Visites
hello
i have a problem with my ASUS V1S, it was working and all was fine, and then suddenly it started to make problems,
i noticed that the fan was working now all the time, so i updated the BIOS to newsest 301AS and all other drivers, now the fan works better, but i noticed performance dropdown (a graphic application was running 100frames (max), now only 30~64)
and i get the Intel ME error during boot and windows tells me :
Error
Symptom:
Cause:
A device has a configuration problem that prevents it from starting properly.
Details:
The
device, Intel Management Engine Interface, cannot start properly. It
may not have the correct driver installed or may be experiencing a
hardware failure. The Plug and Play ID for this device is
PCIVEN_8086-DEV_2A04-SUBSYS_15871043-REV_033-11583659-1-18.
Resolution:
1. Verify the correct driver is installed.
2. Try updating the drivers using Windows Update.
3. Check with the manufacturer for an updated driver.
4. Attempt to uninstall and then reinstall the device using Device Manager.
Related:
Explanation of Error Codes Generated by Device Manager
Manage Devices in Windows
Symptom:
Cause:
A device is disabled preventing it from working properly.
Details:
The
device, Intel Active Management Technology - SOL, is disabled. If
this device is no longer used it may be intentionally disabled. The
PCIVEN_8086-DEV_2A07-SUBSYS_15871043-REV_033-11583659-1-1B.
Resolution:
1. Determine if you need the device.
2. If you need the device, enable it in Device Manager.
3. If you do not use the device it can be left disabled.
Related:
if i try to reinstal the drive for Intel Management Engine Interface from http://downloadcenter.intel.com/confirm.aspx?httpDown=http://downloadmirror.intel.com/14617/eng/HECI_AllOS_3.0.30.1086_PV.exe&agr=N&ProductID=2887&DwnldId=14617&strOSs=All&OSFullName=All%20Operating%20Systems〈=deu
it tells me : The system doesnt meet the minimal requirements to install, setup will abort
i was also seeking help here http://communities.intel.com/thread/1299?tstart=0
what should i do? i dont want to open the nb and manipulate with hw (i would lost my warranty), and would it help either? what did cause this?
thank you
0 Compliments
16 Réponses
Sreelekshm_S_Intel
17 408 Visites
It seems that your system is not properly configured for Intel AMT. Here is a document which will help you to do this.
Also, Which Motherboard are you using? Here is a link that shows a list of all the Motherboards that go with Intel VPro systems. You can select your motherboard and install all the drivers from that link.
http://www.intel.com/products/desktop/motherboard/executive.htm?iid=mbd_main+executive
Sree
0 Compliments
petis
Débutant
17 408 Visites
i have AMT enabled in BIOS, but cant configure it, cause i cannot access the configuration menu (cause of the ME Error, which shows up during boot up)
how do i get to know what my motherboard is, i know i have just "Mobile Intel PM965 Express Chipset"
thats my nb :
http://1toppc.com/Merchant2/merchant.mv?Screen=PROD&Product_Code=V1S-B1
i also cannot install the driver i have from my manufacturer, not even the newest driver from the intel page
thank you
0 Compliments
Ajith_I_Intel
Employé
17 408 Visites
Hi Petis,
From the information you have provided so far, it sounds like the BIOS upgrade did not go fine. I encountered this kind of situation before and reflashing the BIOS helped me. First thing, before the OS boots up, the ME sync messages should not see any errors.
After BIOS POST, once you enter into OS, you have to make sure that the drivers (MEI, LMS etc) match the version of AMT firmware that was distributed in the BIOS. You need to work with ASUS to find out what AMT version of FW they have in there and where you can get the matching drivers for the OS. If the BIOS does not sync ME device properly, then you will see the errors in the OS also.
Let us know how things proceed.
0 Compliments
petis
Débutant
17 408 Visites
it wrote me, that bios was updated succesfull...but i cannot refresh the bios, cause i have the newest one, and it dont let me install older or the same bios...also i reinstal AMT drivers, directly from the Asus support page special for my model
http://support.asus.com/download/download_item.aspx?product=3&model=V1S&SLanguage=de-de
in my BIOS, tehre is an option Unconfiguring AMT [enabled/disable], do you have experience with that?
0 Compliments
petis
Débutant
17 408 Visites
after i install the drivers, all writes ok, but after reboot, it looks like this
http://politea.sk/tmp/Zwischenablage03.jpg
0 Compliments
Sreelekshm_S_Intel
17 408 Visites
Did you enable AMT in the Bios?
Also, the ASUS page that you had provided doesn't show any AMT specific drivers. Did you try contacting them?
Sree
0 Compliments
Meho
Débutant
15 512 Visites
hello can you help me when I'm on windows 10 when I started bios update everything worked fine then the computer turned off and for a few minutes I pressed the button on the computer to turn on then it showed me an error Error sending end of post message to ME how to put my computer running normally fujitsu celsius w420 d3162-c12
0 Compliments
AlHill
Super utilisateur
15 501 Visites
This thread is 13.5 years old.   Start a new thread.
[Windows 11 is the new Vista]
0 Compliments
Meho
Débutant
15 497 Visites
how to fix this error Error sending end of post message to ME
0 Compliments
AlHill
Super utilisateur
15 489 Visites
So, you do not want to start a new thread, eh?
You ME problem is caused by a botched bios update.   Contact your motherboard/system manufacturer for support on correcting their bios update.
0 Compliments
Meho
Débutant
15 488 Visites
yes i want a new one how to fix this error i can't install the operating system because of this error can you help me how to do it
0 Compliments
AlHill
Super utilisateur
15 485 Visites
I alreaady told you how to fix it.  You must contact the manufacturer of your motherboard/system and ask them to help you correct problems with their bios install.   So, if your system is made by HP, or Dell, or if your motherboar is made by ASUS or Gigabyte (for example), you must contact them for support.
0 Compliments
Meho
Débutant
15 480 Visites
isn't your chip or software this intel® management engine bios error sending end of post message to me
0 Compliments
AlHill
Super utilisateur
15 475 Visites
It is the bios that installs the ME.  Unless the board is an intel board, or the system is an intel system, contact the board/system manufacturer for support  WITH THEIR BIOS as I have told you three times now.
0 Compliments
Meho
Débutant
15 474 Visites
i see how you helped these other users here thank you very much now i will talk to the owner of the intel company no sense
0 Compliments
AlHill
Super utilisateur
15 472 Visites
You do not seem to follow instructions very well.   I asked you to start a new thread instead of using a 13+ year old thread.  I told you three times what to do to correct the problem.  Now, you want to talk to the owner, rather than follow some simple instructions.
You do what you want.  In the meantime, you could have done a proper bios recovery and not have the problem,
Good luck.
0 Compliments
Répondre
