Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
Local Manageability Service Taking 50% CPU
johnmsawicki
I have recently purchased a new desktop with INTEL CORE2 CPU [email protected] GHz and 4GM of RAM running Vista Home Premium OS. I noticed that the LMS.EXE file was taking 50% of my CPU processing power. I was told that this was because it was a new system and that this condition would last a few days since the LMS was collecting data from my system, but that it would eventually stop. It did stop for a couple of days but now it is back to using 50% of the CPU constantly. Is this a normal situation?????
I've checked my system and it seems that there are two LMS.exe files on the computer. One is located in my C:|Program filesIntel desktop display boardLMS_SOL_5.2.0.101 and the second location is C:Program filesIntelAMT. Both versions are 2.1.2.1028.
Any guidance in rectifyingthis situation would be extremely appreciated.
John
Sreelekshm_S_Intel
Did you get the LMS file from the OEM? Can you check the task manager and see how many LMS instances are running?
Sree
johnmsawicki
Hi Sree......Yes the LMS file was already loaded when I got the computer...and task manager only show 1 LMS is running
johnmsawicki
acutally SREE...I found two processes running one is (LMS.exe )and the other is lower case (lms.exe)
Sreelekshm_S_Intel
Could you uninstall both of them and re-install the one under AMT folder?
Sree
