Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
1409 Discussions
Moved to SCS and can not un-provision machines from SCCM
Christian_M_1
Hi All,
SCCM 2012 was set up in our environment for some time and was provisioning machines that had the correct version of amt but due the hit and miss way it was working we have decided to move to SCS in database mode. I recently got SCS up and running and with help from this forum it is working to provision all test machines targeted. My problem stems from a  number of devices (around half) at our test site that were provisioned by sccm. I figured it would be as easy as selecting to select 'Remove Provisioning Data'  from sccm before proceeding with SCS to re provision but that has not been the case. Checking the logs on the OOB service point I get the following logs: (I have attached the only bit that seems relevant)
ERROR: Invoke(get) failed: 80020009argNum = 0
Description: A security error occurred
Error: Failed to get AMT_SetupAndConfigurationService instance.
Error: Can NOT get provisioning state from target device. (MachineId = 16781530)
Is this maybe occurring due to the install of SCS and its integration with SCCM prior to removing the provisioning data from sccm?
Any help or insights would be great :)
Christian.
Colleen_C_Intel
I gather from   ERROR: Invoke(get) failed: 80020009argNum = 0 //Description: A security error occurred
that you are not really connecting to the client.  What is your password setting? Have you tried the default (original) password setting to see if the error changes?
Christian_M_1
Thanks Colleen. I was thinking it was a password problem also however the provisioning account section in sccm under OOB Management is fully populated with all accounts and that has not changed. My understanding is that SCCM stores hashed passwords for all devices in its database based on the original MBex password set (could be wrong). Its based on this I was wondering if setting up SCS is somehow preventing SCCM from un-configuring?
If I can provide any more info please let me know.
Gael_H_Intel
You might want to take a look at Blair Muller's blog on integrating SCCM with SCS:  http://blogs.bamits.com.au/2012/09/integrating-sccm-2012-with-scs-81.html
Sounds like a certificate issue - or something is keeping you from accessing AMT.
If all you want to do is take SCCM off your systems - you should be able to clear the cmos and start fresh using SCS (how many systems do you have?)  Some BIOS have an option to disable AMT and if you select that option, reboot and then turn it back on, it will effectively put the system back into factory settings.
Gael
Christian_M_1
The fleet is 4,500 however this issue is affecting around 400 devices at various sites. Based on how far they are spread out it makes it difficult to take the BIOS approach unless I have no other option :/
This is a more detailed log from amtopmgr.log
In this case I am trying to run another discovery and as mentioned the device Status in SCCM is 'Provisioned'
General Worker Thread Pool: Work thread 9580 started    SMS_AMT_OPERATION_MANAGER    26/08/2014 11:37:57 AM    9580 (0x256C)
Discover IPHWS4604 using IP address 172.16.121.128    SMS_AMT_OPERATION_MANAGER    26/08/2014 11:37:57 AM    9580 (0x256C)
DoPingDiscoveryForAMTDevice succeeded.    SMS_AMT_OPERATION_MANAGER    26/08/2014 11:37:57 AM    9580 (0x256C)
Flag iWSManFlagSkipRevocationCheck is set.    SMS_AMT_OPERATION_MANAGER    26/08/2014 11:37:57 AM    9580 (0x256C)
session params : https://IPHWS4604.AU.AD.HSP:16993   ,  2011001    SMS_AMT_OPERATION_MANAGER    26/08/2014 11:37:57 AM    9580 (0x256C)
ERROR: Invoke(get) failed: 80020009argNum = 0    SMS_AMT_OPERATION_MANAGER    26/08/2014 11:37:58 AM    9580 (0x256C)
Description: A security error occurred    SMS_AMT_OPERATION_MANAGER    26/08/2014 11:37:58 AM    9580 (0x256C)
Error: Failed to get AMT_SetupAndConfigurationService instance.    SMS_AMT_OPERATION_MANAGER    26/08/2014 11:37:58 AM    9580 (0x256C)
DoWSManDiscovery failed with user name: admin.    SMS_AMT_OPERATION_MANAGER    26/08/2014 11:37:58 AM    9580 (0x256C)
Flag iWSManFlagSkipRevocationCheck is set.    SMS_AMT_OPERATION_MANAGER    26/08/2014 11:37:58 AM    9580 (0x256C)
session params : https://IPHWS4604.AU.AD.HSP:16993   ,  2011001    SMS_AMT_OPERATION_MANAGER    26/08/2014 11:37:58 AM    9580 (0x256C)
DoWSManDiscovery failed with user name: Default.    SMS_AMT_OPERATION_MANAGER    26/08/2014 11:37:58 AM    9580 (0x256C)
ERROR: Invoke(get) failed: 80020009argNum = 0    SMS_AMT_OPERATION_MANAGER    26/08/2014 11:37:59 AM    9580 (0x256C)
Description: A security error occurred    SMS_AMT_OPERATION_MANAGER    26/08/2014 11:37:59 AM    9580 (0x256C)
Error: Failed to get AMT_SetupAndConfigurationService instance.    SMS_AMT_OPERATION_MANAGER    26/08/2014 11:37:59 AM    9580 (0x256C)
DoWSManDiscovery failed with user name: admin.    SMS_AMT_OPERATION_MANAGER    26/08/2014 11:37:59 AM    9580 (0x256C)
Flag iWSManFlagSkipRevocationCheck is set.    SMS_AMT_OPERATION_MANAGER    26/08/2014 11:37:59 AM    9580 (0x256C)
session params : https://IPHWS4604.AU.AD.HSP:16993   ,  2011001    SMS_AMT_OPERATION_MANAGER    26/08/2014 11:37:59 AM    9580 (0x256C)
DoWSManDiscovery failed with user name: default.    SMS_AMT_OPERATION_MANAGER    26/08/2014 11:37:59 AM    9580 (0x256C)
ERROR: Invoke(get) failed: 80020009argNum = 0    SMS_AMT_OPERATION_MANAGER    26/08/2014 11:38:00 AM    9580 (0x256C)
Description: A security error occurred    SMS_AMT_OPERATION_MANAGER    26/08/2014 11:38:00 AM    9580 (0x256C)
Error: Failed to get AMT_SetupAndConfigurationService instance.    SMS_AMT_OPERATION_MANAGER    26/08/2014 11:38:00 AM    9580 (0x256C)
DoWSManDiscovery failed with user name: Admin.    SMS_AMT_OPERATION_MANAGER    26/08/2014 11:38:00 AM    9580 (0x256C)
Flag iWSManFlagSkipRevocationCheck is set.    SMS_AMT_OPERATION_MANAGER    26/08/2014 11:38:00 AM    9580 (0x256C)
session params : https://IPHWS4604.AU.AD.HSP:16993   ,  2011001    SMS_AMT_OPERATION_MANAGER    26/08/2014 11:38:00 AM    9580 (0x256C)
ERROR: Invoke(get) failed: 80020009argNum = 0    SMS_AMT_OPERATION_MANAGER    26/08/2014 11:38:01 AM    9580 (0x256C)
Description: A security error occurred    SMS_AMT_OPERATION_MANAGER    26/08/2014 11:38:01 AM    9580 (0x256C)
Error: Failed to get AMT_SetupAndConfigurationService instance.    SMS_AMT_OPERATION_MANAGER    26/08/2014 11:38:01 AM    9580 (0x256C)
DoWSManDiscovery failed with user name: admin.    SMS_AMT_OPERATION_MANAGER    26/08/2014 11:38:01 AM    9580 (0x256C)
Start Kerberos Discovery    SMS_AMT_OPERATION_MANAGER    26/08/2014 11:38:01 AM    9580 (0x256C)
Flag iWSManFlagSkipRevocationCheck is set.    SMS_AMT_OPERATION_MANAGER    26/08/2014 11:38:01 AM    9580 (0x256C)
session params : https://IPHWS4604.AU.AD.HSP:16993   ,  2484001    SMS_AMT_OPERATION_MANAGER    26/08/2014 11:38:01 AM    9580 (0x256C)
Description: The network path was not found.    SMS_AMT_OPERATION_MANAGER    26/08/2014 11:38:01 AM    9580 (0x256C)
DoKerberosWSManDiscovery failed.    SMS_AMT_OPERATION_MANAGER    26/08/2014 11:38:01 AM    9580 (0x256C)
session params : https://172.16.121.128:16993   ,  2015001    SMS_AMT_OPERATION_MANAGER    26/08/2014 11:38:01 AM    9580 (0x256C)
DoWSManDiscovery succeeded with user name: admin. AMTStatus = 3.    SMS_AMT_OPERATION_MANAGER    26/08/2014 11:38:02 AM    9580 (0x256C)
Discovery to IP address 172.16.121.128 succeed. AMT status is 3.    SMS_AMT_OPERATION_MANAGER    26/08/2014 11:38:02 AM    9580 (0x256C)
CSMSAMTDiscoveryTask::Execute, discovery to IPHWS4604 succeed. AMT status is 3.    SMS_AMT_OPERATION_MANAGER    26/08/2014 11:38:02 AM    9580 (0x256C)
CSMSAMTDiscoveryTask::Execute - DDR written to C:\Program Files\Microsoft Configuration Manager\inboxes\auth\ddm.box    SMS_AMT_OPERATION_MANAGER    26/08/2014 11:38:02 AM    9580 (0x256C)
CStateMsgReporter::DeliverMessages - Queued message: TT=1201 TIDT=0 TID='Unspecified' SID=10 MUF=0 PCNT=1, P1='IPHWS4604.AU.AD.HSP' P2='' P3='' P4='' P5=''    SMS_AMT_OPERATION_MANAGER    26/08/2014 11:38:02 AM    9580 (0x256C)
CStateMsgReporter::DeliverMessages - Created state message file: C:\Program Files\Microsoft Configuration Manager\inboxes\auth\statesys.box\incoming\q7c1ugpy.SMX    SMS_AMT_OPERATION_MANAGER    26/08/2014 11:38:02 AM    9580 (0x256C)
General Worker Thread Pool: Succeed to run the task IPHWS4604.AU.AD.HSP. Remove it from task list.    SMS_AMT_OPERATION_MANAGER    26/08/2014 11:38:02 AM    9580 (0x256C)
General Worker Thread Pool: Work thread 9580 has been requested to shut down.    SMS_AMT_OPERATION_MANAGER    26/08/2014 11:38:02 AM    9580 (0x256C)
General Worker Thread Pool: Work thread 9580 exiting.    SMS_AMT_OPERATION_MANAGER    26/08/2014 11:38:02 AM    9580 (0x256C)
Colleen_C_Intel
Can you please clarify - is this with just one client or multiple? If it's one - it looks like the ME needs time to wake up before making communication.  Some information on this here.
Christian_M_1
Hi Colleen.
Apologies for the confusion.
This are 400 devices in this state out of a fleet of 4500.  They are currently provisioned via SCCM however now that we are moving to SCS the idea was to unprovision all devices then re-provision into SCS. The client's believe they are provisioned in admin mode and sccm reflects the same however I am unable to do anything with them (KVM, Discovery, Power, Unprovision etc). Here is the full log when I attempt to unprovision one of the 400 devices in this state.
Once again thanks for for your help ;)
>>>>>>>>>>>>>>>Provision task (FullUnprovision) begin<<<<<<<<<<<<<<<    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:15 AM    10064 (0x2750)
Provision target is indicated with SMS resource id. (MachineId = 16783515 ner-pbc0nhc.au.ad.hsp)    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:15 AM    10064 (0x2750)
Found valid basic machine property for machine id = 16783515.    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:15 AM    10064 (0x2750)
The provision mode for device ner-pbc0nhc.au.ad.hsp is 1.    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:15 AM    10064 (0x2750)
The IP addresses of the host ner-pbc0nhc.au.ad.hsp are 172.16.121.119.    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:15 AM    10064 (0x2750)
Flag iWSManFlagSkipRevocationCheck is set.    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:15 AM    10064 (0x2750)
session params : https://ner-pbc0nhc.au.ad.hsp:16993   ,  2011001    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:15 AM    10064 (0x2750)
ERROR: Invoke(get) failed: 80020009argNum = 0    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:16 AM    10064 (0x2750)
Description: A security error occurred    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:16 AM    10064 (0x2750)
Error: Failed to get AMT_SetupAndConfigurationService instance.    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:16 AM    10064 (0x2750)
Error: Can NOT get provisioning state from target device. (MachineId = 16783515)    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:16 AM    10064 (0x2750)
CStateMsgReporter::DeliverMessages - Queued message: TT=1201 TIDT=0 TID='Unspecified' SID=16 MUF=0 PCNT=1, P1='ner-pbc0nhc.au.ad.hsp' P2='' P3='' P4='' P5=''    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:16 AM    10064 (0x2750)
CStateMsgReporter::DeliverMessages - Created state message file: C:\Program Files\Microsoft Configuration Manager\inboxes\auth\statesys.box\incoming\nvzhf6qp.SMX    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:16 AM    10064 (0x2750)
>>>>>>>>>>>>>>>Provision task (FullUnprovision) end<<<<<<<<<<<<<<<    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:16 AM    10064 (0x2750)
General Worker Thread Pool: Warning, Failed to run task this time. Will retry(1) it    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:16 AM    10064 (0x2750)
>>>>>>>>>>>>>>>Provision task (FullUnprovision) begin<<<<<<<<<<<<<<<    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:36 AM    10064 (0x2750)
Provision target is indicated with SMS resource id. (MachineId = 16781435 IPHWS4603.AU.AD.HSP)    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:36 AM    10064 (0x2750)
Found valid basic machine property for machine id = 16781435.    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:36 AM    10064 (0x2750)
The provision mode for device IPHWS4603.AU.AD.HSP is 1.    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:36 AM    10064 (0x2750)
The IP addresses of the host IPHWS4603.AU.AD.HSP are 172.16.121.123.    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:36 AM    10064 (0x2750)
Flag iWSManFlagSkipRevocationCheck is set.    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:36 AM    10064 (0x2750)
session params : https://IPHWS4603.AU.AD.HSP:16993   ,  2011001    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:36 AM    10064 (0x2750)
ERROR: Invoke(get) failed: 80020009argNum = 0    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:37 AM    10064 (0x2750)
Description: A security error occurred    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:37 AM    10064 (0x2750)
Error: Failed to get AMT_SetupAndConfigurationService instance.    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:37 AM    10064 (0x2750)
Error: Can NOT get provisioning state from target device. (MachineId = 16781435)    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:37 AM    10064 (0x2750)
CStateMsgReporter::DeliverMessages - Queued message: TT=1201 TIDT=0 TID='Unspecified' SID=16 MUF=0 PCNT=1, P1='IPHWS4603.AU.AD.HSP' P2='' P3='' P4='' P5=''    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:37 AM    10064 (0x2750)
CStateMsgReporter::DeliverMessages - Created state message file: C:\Program Files\Microsoft Configuration Manager\inboxes\auth\statesys.box\incoming\e8q0a0zk.SMX    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:37 AM    10064 (0x2750)
>>>>>>>>>>>>>>>Provision task (FullUnprovision) end<<<<<<<<<<<<<<<    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:37 AM    10064 (0x2750)
General Worker Thread Pool: Warning, Failed to run task this time. Will retry(2) it    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:37 AM    10064 (0x2750)
>>>>>>>>>>>>>>>Provision task (FullUnprovision) begin<<<<<<<<<<<<<<<    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:57 AM    10064 (0x2750)
Provision target is indicated with SMS resource id. (MachineId = 16781435 IPHWS4603.AU.AD.HSP)    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:57 AM    10064 (0x2750)
Found valid basic machine property for machine id = 16781435.    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:57 AM    10064 (0x2750)
The provision mode for device IPHWS4603.AU.AD.HSP is 1.    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:57 AM    10064 (0x2750)
The IP addresses of the host IPHWS4603.AU.AD.HSP are 172.16.121.123.    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:57 AM    10064 (0x2750)
Flag iWSManFlagSkipRevocationCheck is set.    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:57 AM    10064 (0x2750)
session params : https://IPHWS4603.AU.AD.HSP:16993   ,  2011001    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:57 AM    10064 (0x2750)
ERROR: Invoke(get) failed: 80020009argNum = 0    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:58 AM    10064 (0x2750)
Description: A security error occurred    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:58 AM    10064 (0x2750)
Error: Failed to get AMT_SetupAndConfigurationService instance.    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:58 AM    10064 (0x2750)
Error: Can NOT get provisioning state from target device. (MachineId = 16781435)    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:58 AM    10064 (0x2750)
CStateMsgReporter::DeliverMessages - Queued message: TT=1201 TIDT=0 TID='Unspecified' SID=16 MUF=0 PCNT=1, P1='IPHWS4603.AU.AD.HSP' P2='' P3='' P4='' P5=''    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:58 AM    10064 (0x2750)
CStateMsgReporter::DeliverMessages - Created state message file: C:\Program Files\Microsoft Configuration Manager\inboxes\auth\statesys.box\incoming\1qv038w1.SMX    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:58 AM    10064 (0x2750)
>>>>>>>>>>>>>>>Provision task (FullUnprovision) end<<<<<<<<<<<<<<<    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:58 AM    10064 (0x2750)
General Worker Thread Pool: Warning, Failed to run task this time. Will retry(3) it    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:22:58 AM    10064 (0x2750)
>>>>>>>>>>>>>>>Provision task (FullUnprovision) begin<<<<<<<<<<<<<<<    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:23:18 AM    10064 (0x2750)
Provision target is indicated with SMS resource id. (MachineId = 16781435 IPHWS4603.AU.AD.HSP)    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:23:18 AM    10064 (0x2750)
Found valid basic machine property for machine id = 16781435.    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:23:18 AM    10064 (0x2750)
The provision mode for device IPHWS4603.AU.AD.HSP is 1.    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:23:18 AM    10064 (0x2750)
The IP addresses of the host IPHWS4603.AU.AD.HSP are 172.16.121.123.    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:23:18 AM    10064 (0x2750)
Flag iWSManFlagSkipRevocationCheck is set.    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:23:18 AM    10064 (0x2750)
session params : https://IPHWS4603.AU.AD.HSP:16993   ,  2011001    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:23:18 AM    10064 (0x2750)
ERROR: Invoke(get) failed: 80020009argNum = 0    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:23:19 AM    10064 (0x2750)
Description: A security error occurred    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:23:19 AM    10064 (0x2750)
Error: Failed to get AMT_SetupAndConfigurationService instance.    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:23:19 AM    10064 (0x2750)
Error: Can NOT get provisioning state from target device. (MachineId = 16781435)    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:23:19 AM    10064 (0x2750)
CStateMsgReporter::DeliverMessages - Queued message: TT=1201 TIDT=0 TID='Unspecified' SID=16 MUF=0 PCNT=1, P1='IPHWS4603.AU.AD.HSP' P2='' P3='' P4='' P5=''    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:23:19 AM    10064 (0x2750)
CStateMsgReporter::DeliverMessages - Created state message file: C:\Program Files\Microsoft Configuration Manager\inboxes\auth\statesys.box\incoming\78ombtgj.SMX    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:23:19 AM    10064 (0x2750)
>>>>>>>>>>>>>>>Provision task (FullUnprovision) end<<<<<<<<<<<<<<<    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:23:19 AM    10064 (0x2750)
General Worker Thread Pool: Error, Can not execute the task successfully. Remove it from task list.    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:23:19 AM    10064 (0x2750)
STATMSG: ID=7207 SEV=E LEV=M SOURCE="SMS Server" COMP="SMS_AMT_OPERATION_MANAGER" SYS=AUCLYSCPS01.AU.AD.HSP SITE=CLY PID=1188 TID=10064 GMTDATE=Tue Aug 26 22:23:19.088 2014 ISTR0="unprovision" ISTR1="IPHWS4603.AU.AD.HSP" ISTR2="0x      DD" ISTR3="" ISTR4="" ISTR5="" ISTR6="" ISTR7="" ISTR8="" ISTR9="" NUMATTRS=0    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:23:19 AM    10064 (0x2750)
General Worker Thread Pool: Work thread 10064 has been requested to shut down.    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:23:19 AM    10064 (0x2750)
General Worker Thread Pool: Work thread 10064 exiting.    SMS_AMT_OPERATION_MANAGER    27/08/2014 8:23:19 AM    10064 (0x2750)
Colleen_C_Intel
Can you clarify what version(s) of AMT (and of SCS) that you are using?
Can you try any other reports like just checking provisioning state or other asset?
