Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
PVS-Studio vs AMT SDK
AndreyKarpov
I checked theAMT SDK project using the PVS-Studio static code analyzer. I just glanced through the code but managed to find a few obviously odd fragments. Below I will cite the analyzer-generated messages I have studied and the corresponding code fragments. I hope this will help to improve the project a bit. You may review other odd fragments by downloading PVS-Studio from here.
I can also give you a registration key for some time. You are welcome to ask questions here: feedback.
V501 There are identical sub-expressions to the left and to the right of the '&&' operator: name && uri && name OpenWsmanLib wsman-xml.c 156
static char *make_qname(WsXmlNodeH node, const char *uri, const char *name)
  char *buf = NULL;
  if (name && uri && name) {
Probably need:
if (node && uri && name) {
V576 Incorrect format. A different number of actual arguments is expected while calling 'printf' function. Expected: 1. Present: 2. Discovery discoverysample.cpp 168
bool ParseArgs(int argc, char **argv)
  printf("\\nMust specify a file name when using '-report'.\\n", argv[currArg++]);
False 1 3562 V547 Expression '_username == ""' is always false. To compare strings you should use strcmp() function. Discovery discoverysample.cpp 184 False
static char* _username = "";
static char* _password = "";
static char* _host = "";
static char* _hostMask = "";
Potentional dangerous but some time is work (in all in one obj-module):
if (((_username == "") && (_password != "")) || ((_username != "") && (_password == "")))
V530 The return value of function 'empty' is required to be utilized. AMTredirection mcsol.cpp 443
bool MCSOL::_createHTLink()
  string HTcmd = TERM_CMD;
  HTcmd.empty();
Need: HTcmd.clear();
V576 Incorrect format. A different number of actual arguments is expected while calling 'printf' function. Expected: 1. Present: 2. RemoteControlSample remotecontrolsample.cpp 792
bool GetUserValues(...)
  printf("Error: illegal value. Aborting.\\n", tmp);
  return false;
V547 Expression 'bytesRead < 0' is always false. Unsigned type value is never < 0. RemoteConsole remote.c 173
int ReadFileData(char* fileName, UINT8 data[], size_t size)
  size_t fileSize , bytesRead;
  bytesRead = read(fileno(fileHandle), data, (int) size);
  if (bytesRead < 0)
    printf("Error while Reading file %s : %s", fileName, strerror(errno));
    bytesRead = 0;
V530 The return value of function 'empty' is required to be utilized. EventLogReader cimclass.h 153
void CimClassContainer::Clear()
  for(unsigned int i = 0; i < vec.size(); i++)
    delete vec;
    vec = NULL;
  vec.empty();
Need: vec.clear();
V576 Incorrect format. A different number of actual arguments is expected while calling 'sprintf' function. Expected: 9. Present: 10. ConfigurationServer configurationutils.cpp 236
void StringFromPPS(...)
  sprintf((char *)textPPS, "%04X-%04X-%04X-04X-%04X-%04X-%04X-%04X\\0",
    *(unsigned long *) (hexString),
    *(unsigned short *)(hexString+4),
    *(unsigned short *)(hexString+4+4),
    *(unsigned short *)(hexString+4+4+4),
    *(unsigned short *)(hexString+4+4+4+4),
    *(unsigned short *)(hexString+4+4+4+4+4),
    *(unsigned short *)(hexString+4+4+4+4+4+4),
    *(unsigned short *)(hexString+4+4+4+4+4+4+4)
Need add %:
sprintf((char *)textPPS, "%04X-%04X-%04X- !!!%!!! 04X-%04X-%04X-%04X-%04X\\0",
V511 The sizeof() operator returns size of the pointer, and not of the array, in 'sizeof (pid)' expression. PskGenerator pskgenerator.cpp 126
V511 The sizeof() operator returns size of the pointer, and not of the array, in 'sizeof (pps)' expression. PskGenerator pskgenerator.cpp 127
typedef char PID[pid_len+1];
typedef char PPS[pps_len+1];
static void generate(PID pid, PPS pps)
  memset(pid,0,sizeof(pid));
  memset(pps,0,sizeof(pps));
Need:
memset(pid,0,sizeof(*pid));
memset(pps,0,sizeof(*pps));
V547 Expression 'bytesRead < 0' is always false. Unsigned type value is never < 0. ZTCLocalAgent heciwin.cpp 357
int HECIWin::_doIoctl(...)
  DWORD bytesRead = 0;
  if (bytesRead < 0) {
    Deinit();
V576 Incorrect format. A different number of actual arguments is expected while calling 'fprintf' function. Expected: 2. Present: 3. USBFile usbfile.cpp 489
int WriteXmlFile(...)
  fprintf(fp, "\\n", r.Pps);
V559 Suspicious assignment inside the condition expression of 'if' operator: status = true. AgentPresenceAPIConsole agentpresenceapiconsole.cpp 530
bool SetCBPolicy(...)
  if(status = true)
    PrintSuccess();
  return status;
Need:
if(status == true)
And here:
V559 Suspicious assignment inside the condition expression of 'if' operator: status = true. CircuitBreaker circuitbreakersample.cpp 1637
V519 The '* state' variable is assigned values twice successively. Perhaps this is a mistake. Check lines: 1049, 1050. StorageHelper storagehelper.c 1050
PT_STATUS OpenPTSession(...)
  *state = PT_REGISTERED;
  *state = PT_OPENED;
V576 Incorrect format. A different number of actual arguments is expected while calling '_snprintf' function. Expected: 18. Present: 19. mod_pvs mod_pvs.cpp 308
void addAttribute(...)
  int index = _snprintf(temp, 1023,
    "%02x%02x:%02x%02x:%02x%02x:%02x%02x:%02x%02x:02x%02x:%02x%02x:%02x%02x",
    value[0],value[1],value[2],value[3],value[4],value[5],value[6],value[7],value[8],
    value[9],value[10],value[11],value[12],value[13],value[14],value[15]);
Need add %:
"%02x%02x:%02x%02x:%02x%02x:%02x%02x:%02x%02x: !!!%!!!  02x%02x:%02x%02x:%02x%02x"
V501 There are identical sub-expressions 'options->delivery_password' to the left and to the right of the '||' operator. OpenWsmanLib wsman-client.c 631
static void
wsman_set_subscribe_options(...)
  if(options->delivery_certificatethumbprint ||options->delivery_password ||
     options->delivery_password) {
Need:
if(options->delivery_certificatethumbprint || options->delivery_username ||
Judy_H_Intel
Hi Andrey,
Thanks for the information. We'll take it under advisment.
Cheers,
Judy
