Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
Problem with the F12 key press in the DTK
jacace
Hi there!
When you remote rebot an AMT machine by using the DTK is not possible to make function the F12 key.
In attached picture you can see the three available options when you remote reboot a machine; there you can use F2 and F4, but F12 does not work.
No matter what terminal emulation (VT100, ANSI) or special key translation (intel, alternate, vt100+) you choose.
Thanks a lot,
Javier Andrs Cceres alvis
jacace
I also tried with the v0.6.0937.2 version and I got the same results.
Andrew_S_Intel2
I'm still following up on thisJavier, you might have seen some of theprevious times this question came up and there doesn't seem to be a clean answer. I've been told that there might be an issue due to different OEM implementations of how the higher function keys are handled by the BIOS.
It might be worth a shot trying to use the Send Key Code functionality in the Terminal drop down. The decimal ascii code for F12 is a two character sequence, 00 (NULL), followed by 134. I think you'd enter F12 as "00;134", but I might be mistaken.
Andy
jacace
Andy
Hello Andy,
I modified the source code and I tried these lines with no results:
-serial.Write(new byte[] { 0x00, 0x86 }); //Hex Pair
-serial.Write("00;134"); //decimal pair
-serial.Write("00,134"); //decimal pair
The current DTK's line is:
-serial.Write(new byte[] { 27, 79, 91 });
The key translation was VT100.
Any idea?
Andrew_S_Intel2
Hello Andy,
Any idea?
Javier,
Hmm, yeah I didn't think that it would work, but it was worth a shot.
Could you give me a little more information on the AMT system in question? Since there's likely a BIOS element to this, the specific OEM and AMT version will likely be important for possible troubleshooting. BIOS version might be helpful as well.
Andy
jacace
Javier,
Andy
Hello Andy,
Here some information:
-BIOS: JOQ3510J.86A.0942.2008.0807.1958.
-Intel AMT version: 3.2.1.
-The board is Intel versionAAD82085-701.
The system version and manufacturer is not available.
Andrew_S_Intel2
Hello Andy,
Hmm. Okay, one other thing I can think of to try with the DTK. If you go into the Remote Command drop-down in the AMT terminal, the bottom option is for a Custom Command. If you go in there, one of the Special Command options is Force PXE Boot. That might correspond to the Network Boot option you're seeing with F12 (it would depend on the OEM), in the same way that F2 in the SOL session corresponds to the Remote Reboot to BIOS setup option in the Remote Command drop down.
jacace
Hello Andy,
I tried the "Force PXE Boot" special command option in the AMT terminal but the effect was just a normal reboot.
Javier Andrs
TIMOTHY_D_Intel
Hi Javier,
We'll need to take this one up with engineering. Please submit a bug report (found here) to Support_dopd_swe@intel.com and if you could include refrence to this thread, I'll get this into engineering. Unfortunately we do not have an update planded for the DTK until end of 2009 at the earliest, so I'll be looking for a workaround.
Tim
Gael_H_Intel
Hi Javier,
Tim
Hi Javier,
Did you happen to see Ylian's blog post on this topic? It looks like the customer who wrote the first comment is having the same problem as you are. And I just received a response from Ylian saying that the only solution would be to buy almost any non-intel board. I'll let you know if we can find anything else out.
jacace
Hi Javier,
Hello Gael,
I spent some time researching but now it's enough =(
I'll follow the Ylian's advice.
I downloaded the bug report form but it's so detailed and I think the error scenario it's clear.
Thank you,
Gael_H_Intel
Hello Gael,
Thank you,
Actually, since this is an issue that has been around for years maybe this would be a great addition for you to make in the IdeaZone website. I would vote for it! It is something that customers want and it may have negative effects on your ability to sell your product to them because you cannot provide them a use case that they need in their business. Right?
Lance_A_Intel
I was told that ESC@ may work for F12.
Lance_A_Intel
Also found out that you may be able to work around by using F10 to get to opitons that include network boot.
I'm trying to get F12 support in all platforms and getting info along the way.
jacace
Hello Lance,
I tried ESC@ int two ways but no one worked.
My first approach was:
serial.Write(0x1B);
serial.Write((byte)'@');
My second approach was:
serial.Write(new byte[] { 0x1B, (byte)'@' });
Any suggestion?
Javier Andrs Cceres Alvis
Blog Personal: http://speechflow.spaces.live.com/
Blog Intel: http://software.intel.com/en-us/blogs/author/javierandrescaceres/
Gael_H_Intel
Hello Lance,
serial.Write(0x1B);
Any suggestion?
Hi Javier,
I have sent your question over to the F12 gurus - I'll let you know when I get an answer.
Gael
Gael_H_Intel
Hi Javier,
Gael
Javier - have you tried doing F10 - this should go to a boot list that you should be able to choose PXE from?
Gael_H_Intel
Quoting - DJG78
I'm also experiencingproblems with PXE, only for one specific model
From the OOB console on a HP dc7900 I can't use the intel AMT: options (force pxe boot, force cd/dvd boot, hd boot). The other boot options work perfectly. I'm not experiencing this problem with the HP dc7800, all option function well on the dc7800
I can't find an possible extra setting in BIOS
does anyone have any ideas, i'm not able to find an awnser anywhere
HP dc7900
Bios version: 786G1 v01.16
AMT Firmware version: 5.0.1.1111
Hi - I just checked HP's website and it looks like they have a new BIOs (since June 2009) but they haven't updated their Firmware to 5.1 as of yet. I would upgrade the BIOS at least and see if that helps. If not, you may need to wait until HP offers their updated 5.1 version of the firmware.
