Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
Problems integrating Open MDTK 1.28
Christian_A_
Hi!
I'd like to integrate Open MDTK into one of our company applications. I generated the "Manageability Stack.dll" from the Source and added it into my C# application. I then tried to connect to the system and get the current power state with this code:
AmtSystem sys = new AmtSystem(this.__Hostname, 16992, this.__Username, this.__Password, false, false);
System.Diagnostics.Debug.WriteLine("[AMT] Connecting to " + sys.HostName);
sys.Connect();
while (sys.State == AmtSystemObjState.Connecting)
if (sys.State == AmtSystemObjState.Connected)
	System.Diagnostics.Debug.WriteLine("[AMT] Connected!");
	this.__Response = sys.Remote.GetSystemPowerState().ToString();
	sys.Disconnect();
else
	this.__Response = "Error on connect;";
But the code never enters the connected state. And the strange thing, if I run the code in Release, I get a ton of these (with different field names, sorry for the German):
Eine Ausnahme (erste Chance) des Typs "Intel.Manageability.Exceptions.CimPropertyException" ist in Manageability Stack.dll aufgetreten.
In Intel.Manageability.Exceptions.CimPropertyException ist eine Ausnahme vom Typ "Manageability Stack.dll" aufgetreten, doch wurde diese im Benutzercode nicht verarbeitet.
Zusätzliche Informationen: Logic error:
no such field name: DDNSPeriodicUpdateInterval
The code breaks @CimData.cs in GetField(). I guess it has something to do with the asset management.
What am I doing wrong? The binary software from the installer works, so it has to be my code. Am I missing an assembly?
Kind Regards,
Christian
Christian_A_
I just witnessed something strange:
If I run the App in Release Build Mode from within Visual Studio, I get the above mentioned errors.
If I start the app out of the Release Build folder, MDTK works perfectly and displays the current system status.
So what is the debugger doing different?
Gael_H_Intel
Is there a dll that is in the Release build folder that the exe needs that is not in your path when you run from within Visual Studio?
Interpretation of error:
An exception (first chance) of the type "Intel.Manageability.Exceptions.CimPropertyException 'occurred in Manageability Stack.dll.
In Intel.Manageability.Exceptions.CimPropertyException an exception of type "Manageability Stack.dll" has occurred, but this was not handled in user code.
Additional information: Logic error: no such field name: DDNSPeriodicUpdateInterval
Hopefully, Ylian will get a chance to look at this - I will also take a quick look.
Ylian_S_Intel
Arg. I wrote most of the DTK and I can't say I have ever ran into this problem. Personnaly, I subscribe to the state change event and call "Connect()". I then start the code I want to run after the connect in the event handler. It's better than calling connect and looping. If you are going to loop, put a Thread.Sleep(100) or something in the loop so not to peg the processor.
I never saw this before: "Additional information: Logic error: no such field name: DDNSPeriodicUpdateInterval". I will probably be of no help here.
Ylian
Christian_A_
Here's an update: This time I added the dll from the binary download (mostly because I didn't compile it...), added it to my lib folder, updated the project and rebuild the entire project.
If I run in release config I get what I want, DLL and code work fine.
If I run in debug config I never get to the connected state.
So the initial error with the dozens of missing fields has gone, but when I write my AMT code I can't really debug it.
Any ideas there?
