Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
Problems with IAmtTerm
raul_sanchez
I test for example v0.38 DKT, and with AMT Commander i obtain Serial Agent menu, but with IAmtTerm of this version, i don't have Serial Agent menu (with v0.34f i have the same problem, and with v0.39 i need WSMANAUTOMATION.DLL and i don't obtain this file).
In my application i use IAmtTerm, and i need this Serial Agent menu.
What can i do?
AMT Commander don't use IAmtTerm?
Best regards.
Ylian_S_Intel
Hi. The file "Interop.WSManAutomation.dll" is included with the Intel AMT DTK. It's just a .NET wrapper file for accessing WinRM and yes, if you use IAmtTerm you now need it because I started adding WSMAN support.
As for the serial agent menu, if you use IAmtTerm.exe in TCP mode (like Telnet) that menu is made invisible, but will show up if Intel AMT Outpost or Intel AMT Guardport is present on the Intel AMT computer. Just press the ` key to make it show up. I did this because platforms such as Intel SCS plug-in use IAmtTerm.exe and don't want customers to use these features.
Hope this helps,
Ylian (Intel AMT Blog)
raul_sanchez
OK, it works perfectly.
Best regards.
