Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
Problems with vPro actions
raul_sanchez
We have the problem that when we try send reset command, we obtain http protocol error. I attach an image.
Best regards.
Ajith_I_Intel
Hi Raul,
Can you give us more information on the configuration parameters? It would help us if we know the AMT firmware version, BIOS version, SDK version etc. What mode is the client configured - SMB vs Enterprise? Please let us know the details.
I am assuming that you are using http SOAP interface. Please make sure you are using the correct connection parameters (IP address, port, user credentials etc.) Protocol error could be because of the incorrect usage of the API.
raul_sanchez
The application is the same that i used with other PCs and we didn't have any problems. I use SMB mode and the params are correct. Could i send you by mail a simple sample for test it?
Ylian_S_Intel
Hi. The screen shot shows that you are getting an "Access Denied" error. There is probably nothing wrong with the application, as you say, it works on other computers. Thiserroris coming from Intel AMT. Of course, check that other SOAP commands work and that your username and password are ok (but I am pretty sure this is not access denied due to a bad password).
The first thing I would do is update the BIOS/AMT firmware, older firmwares for Intel AMT 2.0 have such problems. Also, if the Intel AMT computer is in the BIOS screen or in a state where it can't reset, you may get this error. If the computer is already sleeping, you may get this (check the SDK for a table on correct commands). I also know that if you are trying to send a "Power Down" command while IDE-R or SOL sessions are active, you will get this error. Just to check, make sure no IDE-R and SOL sessions are active.
We have seen this before, I remember a post on this forum about this problem. It's likely a firmware update could fix this.
Ylian (Intel AMT Blog)
raul_sanchez
We are desperate... we don't have SOL active and we have updated BIOS and we obtain the same error... What can we test? It is very simple: we are working with Small Business mode with user and password...
A simple test application is in: http://213.201.28.43/EnviosAleatorios/Descargas/20077241228_Debug_Test_VPro_Actions.zip
Please, we need help...
raul_sanchez
We use:
"http://" + this.amtIpAddress + ":" + this.amtPort + "/RemoteControlService";
We believe this web methods have changed, because this funcionality return error now, and before with the same source code, everything worked perfectly...
Ylian_S_Intel
Ok, I will try it today and send back the results. The web methods should not have changed, but I don't completely understand why Intel AMT sometimes can't reset or power-down a computer. I will mail back later...
Ylian_S_Intel
Hi again,
I just tried your application and entered an ip address and the administrator password and hit reset. The tool just locked-up. I would try to reset using the SDK samples, the new Intel AMT SDK 3.0 was released and I would try that first to see if it is your tools or Intel AMT that has a problem.
raul_sanchez
We don't understand...
If i do a simple C#.NET project with a web reference: http://IP:16992/RemoteControlService (Network Interface Guide.doc), we obtain error 401: unauthorized... we can not access to this WS...
raul_sanchez
Please, it is very urgent... we don't know what is the problem...
Gael_H_Intel
Can you verify for us that you have done the things that others in this thread have suggested? Also, please review the SDK doc that discusses Redirection - there are things that need to be done before you can successfully have a SOL/IDER session (like enabling the ports)
raul_sanchez
I have done all the things that in this thread have been suggested and we have reviewed documentation. But i don't understand, i don't want a SOL/IDE session, this works perfectly. I only want to have access to a web method to http://IP:16992/RemoteControlService.
raul_sanchez
Please, we need help... it doesn't work...
We have studied too IntelAmtCmd and IntelAmtRemoteStack, class AmtSytem.cs, and we obtain FAILED_WEB_CALL...
