Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
1412 Discussions
Question about deployment of vPro and AMT with a USB key
postaquestion
I have read a number of references to deployment of vPro and AMT with a USB key to simplify the install, but generally for Enterprise installs. Is this functionality available to configure a machine into Small Business mode, and if so, how would I generate said USB key?
Gael_H_Intel
Currently there is no capability to use a USB key to configure a system in SMB mode. You could probably customize the Intel SCS (downloadable from the Manageability Developers Community web site), to do this...
G H
Jia-Shing_W_Intel
You can also use the Setup & Config Application directly which is part of SCE.
fred29210
The USB key does not configure the AMT portion of the PC. It only loads some initial values to identify itself to the SCS that then configures the PC remotely. The USB key can not be customized, and the USB key can only be used to load these initial values.
