Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
RCT exit code 6 after 3.3 upgrade
frank_monroe
We have been using the following command to provision our systems as part of our automated deployment process. The command has work successfully without issue for several months. However, we recently upgraded SCS from version 3.1 to version 3.3. Since the upgrade the command is failing with error code 6. Any ideas?
rct /s
http://provisionserver/amtscs_rcfg /p 2 /o "OU=Setup,OU=DC,OU=Workstations,DC=mycompany,DC=com" /c /t on
Ajith_I_Intel
Hi Frank,
After you upgraded to 3.3 version of SCS, is this the only thing that is failing? Can you confirm if you can do other operations with SCS? I am also assuming that you are using the rct tool from the new SCS 3.3 distribution. Can you send us a screenshot or any more details regarding the error you are seeing and if the message gets to SCS, can you also enable logging in SCS and send us the logs?
Sreelekshm_S_Intel
We understand that this issue has been resolved with SCS Support. Let us know if you have any more questions.
Sree
