Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
SCS 3.1: Missing ADDN Attribute Error
Gael_H_Intel
The followingissue with the SCS 3.1 has recently been discovered.Setting the OU for Active Directoryto NULL will result in the following error: Missing ADDN Attribute
Workaround: Do not set the Active DirectoryOU to NULL, even if you are not using Active Directory. Seeting the OU field to NULL will result in the above error and provisioning will not be successful.
Yes, there is a blog: Missing ADDN Attribute
