Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
SOAP failure: error code
ph3ar
Is there a reference guide for SOAP failure: error codes?
For example: SOAP failure: error code = 3
It will be very handy for debugging.
Gael_H_Intel
Quoting - ph3ar
Hi ph3ar,
Does this mean you were able to build your Discovery Sample?
--Gael
Lance_A_Intel
Quoting - ph3ar
I'm not aware of any SAOP error code listing.
Are you getting an error now when trying to run an AMT command?
If so, we may be able to help you if you provide more information on your setup and the command you are running.
SOAP errors may indicate that your syntax is incorrect for the command.
ph3ar
Quoting - ph3ar
Hi ph3ar,
--Gael
Hello Gael,
I have compiledagentPresenceConsole SOAP sample on Linux, no lack compiling these samples on windows.
I get the following error when I'm trying to use a proxy with these parameters: -proxyUserName -proxyPassword ] (as refered to the sample's command line help).
ConsoleWatchdogDelete function called
Error: failed while calling DeleteWatchdog
or
SOAP failure: error code = 24
So my point is where shall I seek for these error codes meaning?
Gael_H_Intel
Quoting - ph3ar
Hello Gael,
or
We will need for you tosend over which samples you are trying to run (provide the steps in order for us to reproduce this issue?) and also include the whole command lines for what you are typing in?
You mentioned that you have a proxy server also - how have you provisioned your AMT system? Small Business Mode? Enterprise (TLS/Non TLS?).
