Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
Upgrade Intel IPT with PKI, then CryptImportKey does not work
Kiyoung_K_
ビギナー
3,306件の閲覧回数
I recently upgrade IPT with PKI  from v3.1.0.182 to v4.0.5.25, then I can not use CryptImportKey  any more.
Because it returns 0x000000b7(maybe ERROR_ALREADY_EXISTS) after PIN setting PTD displayed.
Only container created.
I set dwFlags as CRYPT_USER_PROTECTED to use PKI with PTD.
I did not change any source codes, but only changed provider from Intel IPT Enhanced Cryptographic Provider to Intel IPT CSP - Non-Exportable Keys
What is wrong with it? or any misuse?
Is there any solution to it?
Thank you in advance.
0 件の賞賛
1 解決策
Gael_H_Intel
モデレーター
3,299件の閲覧回数
In version 4.x, the secure import and secure export functionality is not supported in the “Intel IPT CSP – Non-Exportable Keys” CSP.
To use secure import or secure export, you must use the new “Intel IPT CSP – Exportable Keys” CSP.
Please let me know if this helps you,
Gael
元の投稿で解決策を見る
10 返答(返信)
Gael_H_Intel
モデレーター
3,306件の閲覧回数
As indicated in the attached Release Notes for v4.0.5.25 and the excerpt below, the name of the Cryptographic Service Providers (CSP) in v4 has changed, and the “Intel IPT Cryptographic Provider” CSP has been removed.  You will need to change your code to use the new CSP names.
Kiyoung_K_
ビギナー
3,299件の閲覧回数
Yes. I changed provider name. It works when I try to generate a new one. But It fails when I try to import a certificate at CryptImportKey step with 0x000000b7 code after CryptAcquireContext success.
Gael_H_Intel
モデレーター
3,300件の閲覧回数
Gael
Kiyoung_K_
ビギナー
3,299件の閲覧回数
I was looking forward to your response :)
You mean that I cannot use certificates in the form of pkcs#12 any more with PTD?
Actually I tried to import through “Intel IPT CSP – Exportable Keys”, but the result was same.
If "secure import" means import through a migration authority,
Then how can I import certificates securely?
There is any technical documents of secure import or detail of changed specification of IPT with PKI?
I am so sorry for too many questions.
I really appreciate your kind and detail answer.
Kiyoung
Gael_H_Intel
モデレーター
3,299件の閲覧回数
I am talking to the experts on this - so that is why there is a delay in my responses.  They are wondering if you are integrating this into a product or if this is a Proof of Concept?
Gael
Kiyoung_K_
ビギナー
3,306件の閲覧回数
In Korea, almost people have one or more certificates already.
So if it is impossible to import certificate, we can not use IPT even though it is a wonderful technology.
I hope I can make many people, companies, and government use Intel IPT with PKI.
Next week. I have to show manufacturers it is possible with a 6th generation machine of them.
Our company finished development with  Intel IPT Enhanced Cryptographic Provider on Broadwell PC.
I tried to use 3.x IPT on new machine, but it was impossible to install on the machine.
Is there any solution?
Kiyoung
Kiyoung_K_
ビギナー
3,306件の閲覧回数
Gael
Yes, We are using IPT with PKI as a main secure certificate storage in our product.
If we can not use it, manufacturers do not make a vPro product line.
Kiyoung
Kiyoung_K_
ビギナー
3,306件の閲覧回数
According to the Release Notes,
Intel IPT Enhanced Cryptographic Provider     The name of this CSP has been changed to: “Intel IPT CSP – Non-Exportable Keys”.
        The functionality of the CSP has not changed.
I think that certificate import should be allowed. if not, it is bug.
Gael_H_Intel
モデレーター
3,306件の閲覧回数
Hi - could you send me your email in a private message?  I need to connect you to our folks who can help you.
Gael
Kiyoung_K_
ビギナー
3,306件の閲覧回数
Gael
I did not receive any message from your folks.
Did you received my message? if not, my email address is kiyoung.kky  at gmail.com.
I have not much time, I have to answer to my customers - manufacturers.
Would you let me know what is going on inside the team?
Thank you,
Kiyoung
返信
