Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
WS-Management and SOAP API's
Dexter1
I was wondering if it's possible to use both ws-manangement and soap api's from AMT SDK in one application. Basically the application uses soap and ws-management commands to support older and newer versions of AMT.
I'd appreciate any help on this.
Thanks!
jacace
Yes it's possible, but you should check first the AMT version to use the rigth option.
Javier Andrs Cceres Alvis
Richard_B_Intel1
Javier is correct in that you can mix both SOAP and WS-MAN API's. However, you might want to consider using the WS-Man Translator for earlier versions of Intel AMT. It can be located at:
http://software.intel.com/en-us/articles/intel-ws-management-translator/
This will allow you to keep your API utilization consistent.
