Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
1409 Discussions
tell me the procedure get hardware asset information
vivekkumarcss_net_in
Sir,
AmtSystem computer = new AmtSystem("192.168.1.9", 16992, "admin", "Coresight1*", false, false);
////// Setup WSMAN support
computer.WsManSupport = Properties.Settings.Default.WsmanSupport;
// Then, connect to the computer.
computer.Connect();
Sir the above code(c#) is to connect amt system.is it right way to connect?.
Afer this i want to call one method that should return hardware information of amt computer.
Sir suggest me that which function i should call now.and how to call that fuction(give the function definition).
Lance_A_Intel
The right way to connect depends on which libraries you are using. If you are using the Manageability Developer Toolkit then you should direct your questions here.
