Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
Android native sdk build problem
Young__Jeff
root@ubuntu:~/src/src/scripts# ./build_android.py
> args: Namespace(debug=False, output_path='/root/src/src/out', target_arch='arm,arm64,x86')
> generating args for arm release
ERROR at //build/config/android/internal_rules.gni:172:23: Can't load input file.
            deps += [ "$_target_label$build_config_target_suffix" ]
Unable to load:
  /root/src/src/modules/audio_device/BUILD.gn
I also checked in the secondary tree for:
  /root/src/src/build/secondary/modules/audio_device/BUILD.gn
The newest source code and 4.2.x branch have the same problem.The "[ "$_target_label$build_config_target_suffix" ]" get wrong path.The right path is "third_party/webrtc/modules/.....".How to modify  "//build/config/android/internal_rules.gni"?Thx.
