I am working with an ASUS https://www.asus.com/Tablets/ASUS_ZenPad_C_70_Z170CG/
The proccesor is an intel QuadCore, the info info is:
processor : 3
vendor_id : GenuineIntel
cpu family : 6
model : 93
model name : Genuine Intel(R) CPU @ 728
stepping : 1
microcode : 0x102
cpu MHz : 900.000
cache size : 512 KB
physical id : 0
siblings : 4
When I try to set the fps to a fixed value, for instances setFPS(15), it ignores and moves around 13 to 24
Code:
Log with fps actually happening:
- Tags:
- HTML5
- JavaScript*
Yes, it's already in roadmap and should be fixed in next major version if the Android system layer can support it. Otherwise, it will be always list as a known issue.
Thanks for reporting this. It is the known issue. We will try to fix it later.
Thanks Lei,
Later means in next version, is it already in the roadmap?
