Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
 Android v4.1 subscription issue  (video not rendered to remoterender)
Gopi_Krishna_P
Hi Team,
in  Android v4.1 video not rendered properly to remoterender (SurfaceViewRenderer) please check below log for information purpose.
Thank you.
Gopi Krishna P.
01-04 15:56:38.945 8274-8418/com.mobile.test I/org.webrtc.Logging: EglRenderer: Duration: 4001 ms. Frames received: 0. Dropped: 0. Rendered: 0. Render fps: 0.0. Average render time: NA. Average swapBuffer time: NA.
01-04 15:56:39.298 8274-9075/com.mobile.test I/org.webrtc.Logging: EglRenderer: full_rendererDuration: 4001 ms. Frames received: 99. Dropped: 0. Rendered: 99. Render fps: 24.7. Average render time: 3235 μs. Average swapBuffer time: 1994 μs.
01-04 15:56:39.300 8274-9074/com.mobile.test I/org.webrtc.Logging: EglRenderer: small_rendererDuration: 4001 ms. Frames received: 0. Dropped: 0. Rendered: 0. Render fps: 0.0. Average render time: NA. Average swapBuffer time: NA.
01-04 15:56:39.940 8274-9051/com.mobile.test I/org.webrtc.Logging: Camera1Enumerator: Index: 0. Camera 0, Facing back, Orientation 90
01-04 15:56:39.941 8274-9051/com.mobile.test I/org.webrtc.Logging: Camera1Enumerator: Index: 1. Camera 1, Facing front, Orientation 270
01-04 15:56:39.942 8274-9051/com.mobile.test I/org.webrtc.Logging: Camera1Enumerator: getCameraIndex: Camera 0, Facing back, Orientation 90
01-04 15:56:39.944 8274-9051/com.mobile.test I/org.webrtc.Logging: Camera1Enumerator: getCameraIndex: Camera 1, Facing front, Orientation 270
01-04 15:56:39.947 8274-9051/com.mobile.test I/org.webrtc.Logging: Camera1Enumerator: Index: 0. Camera 0, Facing back, Orientation 90
01-04 15:56:39.949 8274-9051/com.mobile.test I/org.webrtc.Logging: Camera1Enumerator: Index: 1. Camera 1, Facing front, Orientation 270
01-04 15:56:39.951 8274-9117/com.mobile.test I/org.webrtc.Logging: EglBase14: SDK version: 24. isEGL14Supported: true
01-04 15:56:39.955 8274-9051/com.mobile.test I/org.webrtc.Logging: CameraCapturer: startCapture: 640x480@30
01-04 15:56:39.955 8274-9117/com.mobile.test I/org.webrtc.Logging: Camera1Enumerator: getCameraIndex: Camera 1, Facing front, Orientation 270
01-04 15:56:39.957 8274-9117/com.mobile.test I/org.webrtc.Logging: Camera1Session: Open camera 1
01-04 15:56:39.979 8274-9117/com.mobile.test E/Camera: Camera new cameraInitNormal:0
01-04 15:56:39.984 8274-9117/com.mobile.test I/org.webrtc.Logging: Camera1Session: Available fps ranges: [[14.0:30.0], [30.0:30.0], [14.0:20.0], [20.0:20.0], [14.0:25.0], [25.0:25.0], [12.0:15.0], [15.0:15.0], [14.0:14.0]]
01-04 15:56:39.990 8274-9117/com.mobile.test I/org.webrtc.Logging: Camera1Session: Create new camera1 session on camera 1
01-04 15:56:39.990 8274-9117/com.mobile.test I/org.webrtc.Logging: Camera1Session: Start capturing
01-04 15:56:40.007 8274-9117/com.mobile.test I/org.webrtc.Logging: CameraCapturer: Create session done. Switch state: IDLE. MediaRecorder state: IDLE
01-04 15:56:40.007 8274-9117/com.mobile.test I/org.webrtc.Logging: SurfaceTextureHelper: Setting listener to org.webrtc.Camera1Session$2@f924820
01-04 15:56:40.109 8274-8327/com.mobile.test I/org.webrtc.Logging: WebRtcAudioRecord: initRecording(sampleRate=48000, channels=1)
01-04 15:56:40.110 8274-8327/com.mobile.test I/org.webrtc.Logging: WebRtcAudioRecord: byteBuffer.capacity: 960
01-04 15:56:40.110 8274-8327/com.mobile.test I/org.webrtc.Logging: WebRtcAudioRecord: AudioRecord.getMinBufferSize: 3840
01-04 15:56:40.110 8274-8327/com.mobile.test I/org.webrtc.Logging: WebRtcAudioRecord: bufferSizeInBytes: 7680
01-04 15:56:40.115 8274-8327/com.mobile.test I/org.webrtc.Logging: WebRtcAudioEffects: enable(audioSession=1721)
01-04 15:56:40.115 8274-8327/com.mobile.test I/org.webrtc.Logging: WebRtcAudioRecord: AudioRecord: session ID: 1721, channels: 1, sample rate: 48000
01-04 15:56:40.116 8274-8327/com.mobile.test I/org.webrtc.Logging: WebRtcAudioRecord: AudioRecord: buffer size in frames: 3840
01-04 15:56:40.116 8274-8327/com.mobile.test I/org.webrtc.Logging: WebRtcAudioRecord: startRecording
01-04 15:56:40.119 8274-8327/com.mobile.test I/AudioRecordPermission: remindWithResult:false
01-04 15:56:40.119 8274-8327/com.mobile.test I/HwAudioRecordImpl: checkRecordActive
01-04 15:56:40.129 8274-8327/com.mobile.test I/HwAudioRecordImpl: sendStateChangedIntent, state=3
01-04 15:56:40.131 8274-9166/com.mobile.test I/org.webrtc.Logging: WebRtcAudioRecord: AudioRecordThread@[name=AudioRecordJavaThread, id=3420]
01-04 15:56:40.209 8274-9117/com.mobile.test I/org.webrtc.Logging: SurfaceEglRenderer: small_renderer: Reporting first rendered frame.
01-04 15:56:40.209 8274-9117/com.mobile.test I/org.webrtc.Logging: SurfaceEglRenderer: small_renderer: Reporting frame resolution changed to 640x480 with rotation 0
01-04 15:56:40.209 8274-8274/com.mobile.test I/org.webrtc.Logging: SurfaceViewRenderer: small_renderer: updateSurfaceSize. Layout size: 480x360, frame size: 640x480, requested surface size: 480x360, old surface size: 0x0
01-04 15:56:40.210 8274-9144/com.mobile.test I/org.webrtc.Logging: MediaCodecVideoEncoder: Java initEncode: VIDEO_CODEC_H264. Profile: 0 : 640 x 480. @ 300 kbps. Fps: 60. Encode from texture : false
01-04 15:56:40.214 8274-9144/com.mobile.test I/org.webrtc.Logging: MediaCodecVideoEncoder: Found target encoder for mime video/avc : OMX.IMG.TOPAZ.VIDEO.Encoder. Color: 0x15. Bitrate adjustment: NO_ADJUSTMENT
01-04 15:56:40.214 8274-9144/com.mobile.test I/org.webrtc.Logging: MediaCodecVideoEncoder: Color format: 21. Bitrate adjustment: NO_ADJUSTMENT. Key frame interval: 0 . Initial fps: 30
01-04 15:56:40.214 8274-9144/com.mobile.test I/org.webrtc.Logging: MediaCodecVideoEncoder:   Format: {width=640, height=480, bitrate=300000, mime=video/avc, frame-rate=30, i-frame-interval=20, bitrate-mode=2, color-format=21}
01-04 15:56:40.220 8274-8274/com.mobile.test I/org.webrtc.Logging: SurfaceViewRenderer: small_renderer: onMeasure(). New size: 480x360
01-04 15:56:40.221 8274-8274/com.mobile.test I/org.webrtc.Logging: EglRenderer: small_renderersetLayoutAspectRatio: 1.3333334
01-04 15:56:40.221 8274-8274/com.mobile.test I/org.webrtc.Logging: SurfaceViewRenderer: small_renderer: updateSurfaceSize. Layout size: 480x360, frame size: 640x480, requested surface size: 480x360, old surface size: 480x360
01-04 15:56:40.238 8274-9173/com.mobile.test I/OMXClient: MuxOMX ctor
01-04 15:56:40.255 8274-9173/com.mobile.test I/ACodec: In onAllocateComponent create compenent, codec name: OMX.IMG.TOPAZ.VIDEO.Encoder
01-04 15:56:40.258 8274-9173/com.mobile.test W/ACodec: do not know color format 0x7f000001 = 2130706433
01-04 15:56:40.259 8274-9173/com.mobile.test I/ACodec: setupAVCEncoderParameters with [profile: Baseline] [level: Level52]
01-04 15:56:40.260 8274-9173/com.mobile.test I/ACodec: [OMX.IMG.TOPAZ.VIDEO.Encoder] cannot encode color aspects. Ignoring.
01-04 15:56:40.260 8274-9173/com.mobile.test I/ACodec: [OMX.IMG.TOPAZ.VIDEO.Encoder] cannot encode HDR static metadata. Ignoring.
01-04 15:56:40.260 8274-9173/com.mobile.test I/ACodec: setupVideoEncoder succeeded
01-04 15:56:40.305 8274-9144/com.mobile.test I/org.webrtc.Logging: MediaCodecVideoEncoder: Output buffers: 4
01-04 15:56:40.306 8274-9144/com.mobile.test I/org.webrtc.Logging: MediaCodecVideoEncoder: Input buffers: 5
01-04 15:56:40.307 8274-9144/com.mobile.test I/org.webrtc.Logging: MediaCodecVideoEncoder: Config frame generated. Offset: 0. Size: 44
01-04 15:56:40.307 8274-9144/com.mobile.test I/org.webrtc.Logging: MediaCodecVideoEncoder: 0 0 0 1 67 42 c0 1e
01-04 15:56:40.308 8274-9144/com.mobile.test I/org.webrtc.Logging: MediaCodecVideoEncoder: Java releaseEncoder
01-04 15:56:40.309 8274-9180/com.mobile.test I/org.webrtc.Logging: MediaCodecVideoEncoder: Java releaseEncoder on release thread
01-04 15:56:40.337 8274-9180/com.mobile.test I/org.webrtc.Logging: MediaCodecVideoEncoder: Java releaseEncoder on release thread done
01-04 15:56:40.337 8274-9144/com.mobile.test I/org.webrtc.Logging: MediaCodecVideoEncoder: Java releaseEncoder done
01-04 15:56:40.338 8274-9144/com.mobile.test I/org.webrtc.Logging: MediaCodecVideoEncoder: Java initEncode: VIDEO_CODEC_H264. Profile: 0 : 640 x 480. @ 300 kbps. Fps: 30. Encode from texture : true
01-04 15:56:40.340 8274-9144/com.mobile.test I/org.webrtc.Logging: MediaCodecVideoEncoder: Found target encoder for mime video/avc : OMX.IMG.TOPAZ.VIDEO.Encoder. Color: 0x7f000789. Bitrate adjustment: NO_ADJUSTMENT
01-04 15:56:40.340 8274-9144/com.mobile.test I/org.webrtc.Logging: MediaCodecVideoEncoder: Color format: 2130708361. Bitrate adjustment: NO_ADJUSTMENT. Key frame interval: 0 . Initial fps: 30
01-04 15:56:40.340 8274-9144/com.mobile.test I/org.webrtc.Logging: MediaCodecVideoEncoder:   Format: {width=640, height=480, bitrate=300000, mime=video/avc, frame-rate=30, i-frame-interval=20, bitrate-mode=2, color-format=2130708361}
01-04 15:56:40.343 8274-9182/com.mobile.test I/OMXClient: MuxOMX ctor
01-04 15:56:40.348 8274-9182/com.mobile.test I/ACodec: In onAllocateComponent create compenent, codec name: OMX.IMG.TOPAZ.VIDEO.Encoder
01-04 15:56:40.350 8274-9182/com.mobile.test W/ACodec: do not know color format 0x7f000001 = 2130706433
01-04 15:56:40.351 8274-9182/com.mobile.test W/ACodec: do not know color format 0x7f000005 = 2130706437
01-04 15:56:40.351 8274-9182/com.mobile.test W/ACodec: do not know color format 0x7f000002 = 2130706434
01-04 15:56:40.352 8274-9182/com.mobile.test W/ACodec: do not know color format 0x7f000006 = 2130706438
01-04 15:56:40.352 8274-9182/com.mobile.test W/ACodec: do not know color format 0x17 = 23
01-04 15:56:40.352 8274-9182/com.mobile.test W/ACodec: do not know color format 0x18 = 24
01-04 15:56:40.353 8274-9182/com.mobile.test W/ACodec: do not know color format 0x7f000011 = 2130706449
01-04 15:56:40.353 8274-9182/com.mobile.test W/ACodec: do not know color format 0x16 = 22
01-04 15:56:40.353 8274-9182/com.mobile.test W/ACodec: do not know color format 0x7f000007 = 2130706439
01-04 15:56:40.354 8274-9182/com.mobile.test W/ACodec: do not know color format 0x7f000008 = 2130706440
01-04 15:56:40.354 8274-9182/com.mobile.test W/ACodec: do not know color format 0x19 = 25
01-04 15:56:40.354 8274-9182/com.mobile.test W/ACodec: do not know color format 0x1a = 26
01-04 15:56:40.355 8274-9182/com.mobile.test W/ACodec: do not know color format 0x1b = 27
01-04 15:56:40.355 8274-9182/com.mobile.test W/ACodec: do not know color format 0x1c = 28
01-04 15:56:40.355 8274-9182/com.mobile.test W/ACodec: do not know color format 0x7f000003 = 2130706435
01-04 15:56:40.356 8274-9182/com.mobile.test W/ACodec: do not know color format 0x7f000009 = 2130706441
01-04 15:56:40.356 8274-9182/com.mobile.test W/ACodec: do not know color format 0x7f00000c = 2130706444
01-04 15:56:40.356 8274-9182/com.mobile.test W/ACodec: do not know color format 0x7f000012 = 2130706450
01-04 15:56:40.356 8274-9182/com.mobile.test W/ACodec: do not know color format 0x7f00000a = 2130706442
01-04 15:56:40.357 8274-9182/com.mobile.test W/ACodec: do not know color format 0x7f00000b = 2130706443
01-04 15:56:40.357 8274-9182/com.mobile.test W/ACodec: do not know color format 0x7f000789 = 2130708361
01-04 15:56:40.358 8274-9182/com.mobile.test I/ACodec: setupAVCEncoderParameters with [profile: Baseline] [level: Level52]
01-04 15:56:40.358 8274-9182/com.mobile.test I/ACodec: [OMX.IMG.TOPAZ.VIDEO.Encoder] cannot encode color aspects. Ignoring.
01-04 15:56:40.359 8274-9182/com.mobile.test I/ACodec: [OMX.IMG.TOPAZ.VIDEO.Encoder] cannot encode HDR static metadata. Ignoring.
01-04 15:56:40.359 8274-9182/com.mobile.test I/ACodec: setupVideoEncoder succeeded
01-04 15:56:40.359 8274-9182/com.mobile.test W/ACodec: do not know color format 0x7f000789 = 2130708361
01-04 15:56:40.406 8274-9144/com.mobile.test I/org.webrtc.Logging: MediaCodecVideoEncoder: Output buffers: 4
01-04 15:56:40.406 8274-9144/com.mobile.test I/org.webrtc.Logging: MediaCodecVideoEncoder: Sync frame request
01-04 15:56:40.417 8274-9144/com.mobile.test I/org.webrtc.Logging: MediaCodecVideoEncoder: Config frame generated. Offset: 0. Size: 44
01-04 15:56:40.417 8274-9144/com.mobile.test I/org.webrtc.Logging: MediaCodecVideoEncoder: 0 0 0 1 67 42 c0 1e
01-04 15:56:40.435 8274-9144/com.mobile.test I/org.webrtc.Logging: MediaCodecVideoEncoder: Sync frame generated
01-04 15:56:40.435 8274-9144/com.mobile.test I/org.webrtc.Logging: MediaCodecVideoEncoder: Appending config frame of size 44 to output buffer with offset 0, size 1424
01-04 15:56:41.893 8274-8580/com.mobile.test I/org.webrtc.Logging: EglRenderer: Duration: 4004 ms. Frames received: 0. Dropped: 0. Rendered: 0. Render fps: 0.0. Average render time: NA. Average swapBuffer time: NA.
01-04 15:56:42.007 8274-9117/com.mobile.test I/org.webrtc.Logging: CameraStatistics: Camera fps: 25.
01-04 15:56:42.172 8274-8931/com.mobile.test I/org.webrtc.Logging: EglRenderer: Duration: 4001 ms. Frames received: 0. Dropped: 0. Rendered: 0. Render fps: 0.0. Average render time: NA. Average swapBuffer time: NA.
01-04 15:56:42.279 8274-8796/com.mobile.test I/org.webrtc.Logging: EglRenderer: Duration: 4002 ms. Frames received: 0. Dropped: 0. Rendered: 0. Render fps: 0.0. Average render time: NA. Average swapBuffer time: NA.
01-04 15:56:42.746 8274-9088/com.mobile.test W/org.webrtc.Logging: MediaCodecVideoDecoder: Draining decoder. Dropping frame with TS: 11633. Total number of dropped frames: 1
01-04 15:56:42.768 8274-9088/com.mobile.test W/org.webrtc.Logging: MediaCodecVideoDecoder: Draining decoder. Dropping frame with TS: 11700. Total number of dropped frames: 2
01-04 15:56:42.804 8274-9088/com.mobile.test W/org.webrtc.Logging: MediaCodecVideoDecoder: Draining decoder. Dropping frame with TS: 11800. Total number of dropped frames: 3
01-04 15:56:42.838 8274-9088/com.mobile.test W/org.webrtc.Logging: MediaCodecVideoDecoder: Draining decoder. Dropping frame with TS: 11900. Total number of dropped frames: 4
01-04 15:56:42.871 8274-9088/com.mobile.test W/org.webrtc.Logging: MediaCodecVideoDecoder: Draining decoder. Dropping frame with TS: 12000. Total number of dropped frames: 5
01-04 15:56:42.907 8274-9088/com.mobile.test W/org.webrtc.Logging: MediaCodecVideoDecoder: Draining decoder. Dropping frame with TS: 12100. Total number of dropped frames: 6
01-04 15:56:42.940 8274-9088/com.mobile.test W/org.webrtc.Logging: MediaCodecVideoDecoder: Draining decoder. Dropping frame with TS: 12200. Total number of dropped frames: 7
01-04 15:56:42.949 8274-8418/com.mobile.test I/org.webrtc.Logging: EglRenderer: Duration: 4004 ms. Frames received: 0. Dropped: 0. Rendered: 0. Render fps: 0.0. Average render time: NA. Average swapBuffer time: NA.
01-04 15:56:42.973 8274-9088/com.mobile.test W/org.webrtc.Logging: MediaCodecVideoDecoder: Draining decoder. Dropping frame with TS: 12300. Total number of dropped frames: 8
01-04 15:56:43.027 8274-9088/com.mobile.test W/org.webrtc.Logging: MediaCodecVideoDecoder: Draining decoder. Dropping frame with TS: 12433. Total number of dropped frames: 9
01-04 15:56:43.041 8274-9088/com.mobile.test W/org.webrtc.Logging: MediaCodecVideoDecoder: Draining decoder. Dropping frame with TS: 12500. Total number of dropped frames: 10
01-04 15:56:43.078 8274-9088/com.mobile.test W/org.webrtc.Logging: MediaCodecVideoDecoder: Too many output buffers 2. Dropping frame with TS: 12600. Total number of dropped frames: 11
01-04 15:56:43.298 8274-9075/com.mobile.test I/org.webrtc.Logging: EglRenderer: full_rendererDuration: 4000 ms. Frames received: 83. Dropped: 0. Rendered: 83. Render fps: 20.7. Average render time: 6295 μs. Average swapBuffer time: 3562 μs.
01-04 15:56:43.301 8274-9074/com.mobile.test I/org.webrtc.Logging: EglRenderer: small_rendererDuration: 4000 ms. Frames received: 89. Dropped: 0. Rendered: 89. Render fps: 22.2. Average render time: 3202 μs. Average swapBuffer time: 1838 μs.
01-04 15:56:44.007 8274-9117/com.mobile.test I/org.webrtc.Logging: CameraStatistics: Camera fps: 30.
01-04 15:56:45.897 8274-8580/com.mobile.test I/org.webrtc.Logging: EglRenderer: Duration: 4004 ms. Frames received: 0. Dropped: 0. Rendered: 0. Render fps: 0.0. Average render time: NA. Average swapBuffer time: NA.
01-04 15:56:46.008 8274-9117/com.mobile.test I/org.webrtc.Logging: CameraStatistics: Camera fps: 31.
01-04 15:56:46.176 8274-8931/com.mobile.test I/org.webrtc.Logging: EglRenderer: Duration: 4004 ms. Frames received: 0. Dropped: 0. Rendered: 0. Render fps: 0.0. Average render time: NA. Average swapBuffer time: NA.
01-04 15:56:46.283 8274-8796/com.mobile.test I/org.webrtc.Logging: EglRenderer: Duration: 4003 ms. Frames received: 0. Dropped: 0. Rendered: 0. Render fps: 0.0. Average render time: NA. Average swapBuffer time: NA.
01-04 15:56:46.951 8274-8418/com.mobile.test I/org.webrtc.Logging: EglRenderer: Duration: 4001 ms. Frames received: 0. Dropped: 0. Rendered: 0. Render fps: 0.0. Average render time: NA. Average swapBuffer time: NA.
01-04 15:56:47.298 8274-9075/com.mobile.test I/org.webrtc.Logging: EglRenderer: full_rendererDuration: 4000 ms. Frames received: 102. Dropped: 0. Rendered: 102. Render fps: 25.5. Average render time: 3525 μs. Average swapBuffer time: 2151 μs.
01-04 15:56:47.301 8274-9074/com.mobile.test I/org.webrtc.Logging: EglRenderer: small_rendererDuration: 4000 ms. Frames received: 121. Dropped: 0. Rendered: 121. Render fps: 30.2. Average render time: 2755 μs. Average swapBuffer time: 1636 μs.
01-04 15:56:48.008 8274-9117/com.mobile.test I/org.webrtc.Logging: CameraStatistics: Camera fps: 30.
01-04 15:56:49.899 8274-8580/com.mobile.test I/org.webrtc.Logging: EglRenderer: Duration: 4001 ms. Frames received: 0. Dropped: 0. Rendered: 0. Render fps: 0.0. Average render time: NA. Average swapBuffer time: NA.
01-04 15:56:50.008 8274-9117/com.mobile.test I/org.webrtc.Logging: CameraStatistics: Camera fps: 31.
01-04 15:56:50.179 8274-8931/com.mobile.test I/org.webrtc.Logging: EglRenderer: Duration: 4002 ms. Frames received: 0. Dropped: 0. Rendered: 0. Render fps: 0.0. Average render time: NA. Average swapBuffer time: NA.
01-04 15:56:50.287 8274-8796/com.mobile.test I/org.webrtc.Logging: EglRenderer: Duration: 4005 ms. Frames received: 0. Dropped: 0. Rendered: 0. Render fps: 0.0. Average render time: NA. Average swapBuffer time: NA.
01-04 15:56:50.867 8274-8331/com.mobile.test I/org.webrtc.Logging: WebRtcAudioManager: VOICE_CALL stream volume: 5 (max=5)
01-04 15:56:50.955 8274-8418/com.mobile.test I/org.webrtc.Logging: EglRenderer: Duration: 4004 ms. Frames received: 0. Dropped: 0. Rendered: 0. Render fps: 0.0. Average render time: NA. Average swapBuffer time: NA.
01-04 15:56:51.298 8274-9075/com.mobile.test I/org.webrtc.Logging: EglRenderer: full_rendererDuration: 3999 ms. Frames
Gopi_Krishna_P
Any help would be appreciated.
Thank you.
Gopi Krishna P
Gopi_Krishna_P
Issue resolved due to ContextInitialization properly not initialized
Thank you.
Gopi Krishna P
He_Z_Intel
Thank you.
Gopi Krishna P
Good to know you rooted the cause and fixed it. :)
Please feel free to share your experience and problems with us.
