Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
1151 Discussions
Configuring external IP of WebRTC Gateway
Lars_O_
I am trying to run the WebRTC Gateway on EC2 and I am running in to a problem where the remote candidate IP's returned to my browser is the local IP of the EC2 instance where the gateway is running, and not the external IP of the EC2 instance. Is it possible to configure the WebRTC Gateway to return the external IP of the machine it is running on and not the IP of the interface it is running on?
A more general question is also where I can find documentation of the gateway_config.json?
Lars
Lars_O_
Note: this happens even when I set the publicIP field of gateway_config.json to the public IP of the machine.
Chunbo_H_Intel1
Which version of SIP Gateway are you using?
Thanks!
Lars_O_
Hi Chunbo,
I'm using the 3.1 release.
Lars
Lei_Z_Intel1
Hi, Lars
It should work with publicIP setting of gateway_config.json. But there is defect in current SIP Gateway. This will be fixed in coming v3.2.1 release. Thanks for your patience.
Best wishes,
Zhai Lei
Nithin_P_
            I am using sdk version 3.3. I have configured mcu server in aws server. But the server taking private ip address of the instance for sdp creation.So unable to establish peer connection " woogeen.sdk.js:8 ERROR: publish failed: peer connection failed".
sdp offer like the following
c=IN IP4 0.0.0.0
a=rtcp:1 IN IP4 0.0.0.0
a=candidate:1 1 udp 2013266431 172.31.23.171 47623 typ host generation 0
a=ice-ufrag:DSf8
a=ice-pwd:n6jpgutZPo925c3DqhQrdq
In the above sdp ip address is 172.31.23.171. But it is the private ip address of my instance. I need public ip address in place.
I did not configure private ip address anywhere webrtc server automatically ditect the private ip. How can force the intel webrtc server to take public ip address in place private one.
This my application url please check :    https://13.228.230.100:3004/
Thank you,
