Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
Error when starting OWT Server
tecnologia_info__SEI
I installed a OWT Server in CentOS 7, when I try to start, it gives me this error:
[root@srvwebrtc-mt ~]# bash /opt/CS_WebRTC_Intel/bin/init-all.sh --hardware
Initializing with hardware msdk
Initializing mongodb...
Start mongodb - "systemctl start mongod"
Start rabbitmq-server - "systemctl start rabbitmq-server"
Initializing ManagementAPIServer configuration...
superServiceId: 5e42fc751ebfbd320f3ab986
superServiceKey: aTFieOLabgYlXzqAEqPXd09dXNXGeDK3U2BExANujnnJn8/mnKG9ROqsTgVr/w1kU8AflRDa/xTsd6AQv9p9m+TLFq386MtheWmppW4ofzRshcnMMOGF3/TPJ3osDo1NlH/sriOt8B86sSoykLsTHX3kCka3wALrAK+lpx4vtl8=
sampleServiceId: 5e42fc751ebfbd320f3ab987
sampleServiceKey: SuoLP0GISYr9DYWBWi3whmj44adXvWcXfo+gGFl6q9IZCyGsZVq/Mvk43myCvwoXIlgR06rX77VCYaIVHU5amNOpdzNJOn1wzNWYCgl4gFv6iZpUvWHWStGFnHoEgsXPwvATw7ZzHvgwSqsXXjZKESIpqcq2UUmEWOrbRp6GAmg=
Hardware acceleration enabled
Update RabbitMQ/MongoDB Account? [No/yes]
[root@srvwebrtc-mt ~]# bash /opt/CS_WebRTC_Intel/bin/start-all.sh
starting management-api, stdout -> /opt/CS_WebRTC_Intel/logs/management-api.stdout
starting cluster-manager, stdout -> /opt/CS_WebRTC_Intel/logs/cluster-manager.stdout
starting analytics-agent, stdout -> /opt/CS_WebRTC_Intel/logs/analytics-agent.stdout
starting audio-agent, stdout -> /opt/CS_WebRTC_Intel/logs/audio-agent.stdout
starting conference-agent, stdout -> /opt/CS_WebRTC_Intel/logs/conference-agent.stdout
starting recording-agent, stdout -> /opt/CS_WebRTC_Intel/logs/recording-agent.stdout
starting sip-agent, stdout -> /opt/CS_WebRTC_Intel/logs/sip-agent.stdout
starting streaming-agent, stdout -> /opt/CS_WebRTC_Intel/logs/streaming-agent.stdout
starting video-agent, stdout -> /opt/CS_WebRTC_Intel/logs/video-agent.stdout
starting webrtc-agent, stdout -> /opt/CS_WebRTC_Intel/logs/webrtc-agent.stdout
starting management-console, stdout -> /opt/CS_WebRTC_Intel/logs/management-console.stdout
starting portal, stdout -> /opt/CS_WebRTC_Intel/logs/portal.stdout
starting sip-portal, stdout -> /opt/CS_WebRTC_Intel/logs/sip-portal.stdout
auth failed
auth failed
starting app, stdout -> /opt/CS_WebRTC_Intel/logs/app.stdout
Build http(s) req error: { Error: connect ECONNREFUSED 127.0.0.1:3000
    at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1191:14)
  errno: 'ECONNREFUSED',
  code: 'ECONNREFUSED',
  syscall: 'connect',
  address: '127.0.0.1',
  port: 3000 }
getRooms failed( 503 ): { Error: connect ECONNREFUSED 127.0.0.1:3000
[root@srvwebrtc-mt ~]# nmap localhost
Starting Nmap 6.40 ( http://nmap.org ) at 2020-02-12 17:04 -04
Nmap scan report for localhost (127.0.0.1)
Host is up (0.0000020s latency).
rDNS record for 127.0.0.1: localhost.localdomain
Not shown: 994 closed ports
PORT     STATE SERVICE
22/tcp   open  ssh
25/tcp   open  smtp
111/tcp  open  rpcbind
631/tcp  open  ipp
3001/tcp open  nessus
9090/tcp open  zeus-admin
Any ideas?
YanbinZ_Intel
Please Make sure management-api is started correctly . Could you please check any error message in management-api.stdout log?
Yanbin
