Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
1151 Discussions
How can i change self bit-rate and subscription bit-rate
Nikhil_kumar__Doosar
Hello team,
we are using intel cs (v4.1) ,how we can change bit-rate or frames per second  on fly .
Nikhil
Qiujiao_W_Intel
You can specify maxBitrate in video and audio options when publishing local stream, and once it's published, the published stream bitrate is fixed. For subscription bitrate, you can specify resolution, fps and bitrateMutiplier to a specified bitrate. If you want to change subscribed  stream's bitrate, use subscription.applyOptions to update the subscription options.
