Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
1151 Discussions
Issue when using Media Analytics Server: stalled video analyzer
van_der_Vliet__Bart
I'm trying to get the supplied Face detection OpenVINO Media Analytics plugin working as described in https://software.intel.com/en-us/articles/intel-collaboration-suite-for-webrtc-media-analytics-server-guide, but I'm stuck doing so. I configured the system and got below output once in a worker log, but could never reproduce it ever since. I'm configuring the Collaboration Suite 4.1.
to initialize video analyzer
Failed to dlopen
Video analytics engine init OK.
2019-03-26 13:36:35.639 - INFO: AmqpClient - Connecting to rabbitMQ server OK, hostPort: { host: 'localhost', port: '5672' }
sender initialized as rpc server ok.
received request from controller to start analytics.
Pre-Joining to MCU with token:"xxx"
start analytics ok!
[2019-03-26 13:36:35] [connect] Successful connection
[2019-03-26 13:36:35] [connect] WebSocket Connection 10.8.0.1:8080 v-2 "WebSocket++/0.7.0" /socket.io/?EIO=4&transport=websocket&t=1553603795 101
Connected to MCU
Requested stream id is:151645106555232900
current parsed stream id is:5c4f054c768a2211be3b8be6-common
current parsed stream id is:151645106555232900
subscribing stream start!
Publishing the stream start.......
Subscription succeed!
Successfully publishing the stream
2019-03-26 14:12:26.326 - WARN: VideoAnalyticsNode - Exiting on SIGTERM
exiting analytics worker
Since then I am only getting below output in the worker logs, I already tried restarting the collaboration suite and media analyzer systems and restarting the machine:
Failed to dlopen
2019-03-26 14:49:04.125 - INFO: AmqpClient - Connecting to rabbitMQ server OK, hostPort: { host: 'localhost', port: '5672' }
As you can see it stalls while calling the "engine.addAnalyticsForStream" and never gets to the callback() function. Then, after 6 seconds or so in the analyzer logs I get the message that there was a timeout while doing the RPC call.
Because I cannot see what happens in the VideoAnalyzer engine, I'm kind of stuck here.
Can anybody point me in the right direction?
