Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
Issue with starting OWT server
Arjun
I installed OWT server from this https://github.com/open-webrtc-toolkit/owt-server/blob/master/doc/servermd/Server.md . When I tried to start the server, I am getting error in starting the management-console. I checked the managment-api.stdout file. Here is the error which I am getting
failed to connect to server [localhost:27017] on first connect [MongoError: connect ECONNREFUSED 127.0.0.1:27017]
2020-07-29 18:55:28.570  - INFO: ManagementServer - Worker 6057 started
events.js:183
      throw er; // Unhandled 'error' event
Error: bind EADDRINUSE null:3000
    at Object._errnoException (util.js:1022:11)
    at _exceptionWithHostPort (util.js:1044:20)
    at listenOnMasterHandle (net.js:1427:16)
    at rr (internal/cluster/child.js:121:12)
    at Worker.send (internal/cluster/child.js:88:7)
    at process.onInternalMessage (internal/cluster/utils.js:42:8)
    at emitTwo (events.js:131:20)
    at process.emit (events.js:214:7)
    at emit (internal/child_process.js:772:12)
    at _combinedTickCallback (internal/process/next_tick.js:141:11)
    at process._tickCallback (internal/process/next_tick.js:180:9)
2020-07-29 18:55:28.699  - INFO: ManagementServer - Worker 6057 died
2020-07-29 18:55:29.154  - INFO: ManagementServer - Worker 6072 started
2020-07-29 18:55:29.302  - INFO: RPC - Connected to rabbitMQ server
events.js:183
2020-07-29 18:55:29.323  - INFO: ManagementServer - Worker 6072 died
2020-07-29 18:55:29.341  - INFO: ManagementServer - Worker 6073 started
events.js:183
2020-07-29 18:55:29.410  - INFO: ManagementServer - Worker 6073 died
2020-07-29 18:55:29.531  - INFO: ManagementServer - Worker 6056 started
events.js:183
2020-07-29 18:55:29.608  - INFO: ManagementServer - Worker 6056 died
Please help me if you have any idea regarding this error. Thank you
Ravi_Prakash
 make sure, you have installed MongoDB and it is running.
