Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
JS SDK 4.0 require failed
Bikbaev__Timur1
Ive download JS SDK 4.0 and put it on simple script:
/*global require, __dirname, console, process*/
'use strict';
var N = require('./ics')
But when im trying to run this script i have an error:
node test.js
/home/ubuntu/Release-v4.0/extras/tcast-conference-server-nodejs/ics.js:9
!function(e){if("object"==typeof exports&&"undefined"!=typeof module)module.exports=e();else if("function"==typeof define&&define.amd)define([],e);else{("undefined"!=typeof window?window:"undefined"!=typeof global?global:"undefined"!=typeof self?self:this).Ics=e()}}(function(){return function(){return function e(t,n,i){function r(a,s){if(!n){if(!t){var c="function"==typeof require&&require;if(!s&&c)return c(a,!0);if(o)return o(a,!0);var u=new Error("Cannot find module '"+a+"'");throw u.code="MODULE_NOT_FOUND",u}var d=n={exports:{}};t[0].call(d.exports,function(e){return r(t[1]||e)},d,d.exports,e,t,n,i)}return n.exports}for(var o="function"==typeof require&&require,a=0;a<i.length;a++)r(i);return r}}()({1:[function(e,t,n){"use strict";Object.defineProperty(n,"__esModule",{value:!0});n.Base64=function(){var e,t,n,i,r,o,a,s,c;for(-1,e=["A","B","C","D","E","F","G","H","I","J","K","L","M","N","O","P","Q","R","S","T","
ReferenceError: window is not defined
    at /home/ubuntu/Release-v4.0/extras/tcast-conference-server-nodejs/ics.js:9:5400
    at Object.5 (/home/ubuntu/Release-v4.0/extras/tcast-conference-server-nodejs/ics.js:9:5753)
    at r (/home/ubuntu/Release-v4.0/extras/tcast-conference-server-nodejs/ics.js:9:556)
    at /home/ubuntu/Release-v4.0/extras/tcast-conference-server-nodejs/ics.js:9:590
    at Object.7../logger.js (/home/ubuntu/Release-v4.0/extras/tcast-conference-server-nodejs/ics.js:9:6904)
    at Object.4../mediaformat.js (/home/ubuntu/Release-v4.0/extras/tcast-conference-server-nodejs/ics.js:9:4650)
Did i need to install something or i just miss something? ( ive checked with prev version(3.5.2, nuve.js) - everything works fine)
Bikbaev__Timur1
adapter.js and socket.io.js added to script - same error
Qiujiao_W_Intel
Did you run your code in browsers? As the error showed Windows is defined in browser and it cannot be found in your environment
Bikbaev__Timur1
nope, ive tried run this script on server with "node" command ( previous version = nuve.js) is working fine. Reason why im not using browser cuase we already have our custom app  and we want to upgrade it to ver.4
Qiujiao_W_Intel
Hi, how do you use nuve.js in 3.5? to manage room related resources? If so you can use rest.js in 4.0, please refer to our document.
