Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
1151 Discussions
MCU returns negative ack for unpublishing, Invalid stream id
Ravi_Prakash
Hi Team,
I m trying to publish a screen-cast to the conference,  where I have already published the local stream. It happens randomly but frequently.
The Error is thrown by OWT.js
Here is my code:-
shareScreenStream(userEmail, roomId) {
        let screenStream;
        let mediaScreenStream;
        // audioConstraintsForScreen
        let audioConstraints = new Owt.Base.AudioTrackConstraints(Owt.Base.AudioSourceInfo.SCREENCAST);
        // videoConstraintsForScreen
        let videoConstraints = new Owt.Base.VideoTrackConstraints(Owt.Base.VideoSourceInfo.SCREENCAST);
        Owt.Base.MediaStreamFactory.createMediaStream(new Owt.Base.StreamConstraints(audioConstraints, videoConstraints)).then(stream => {
            mediaScreenStream = stream;
            $('#local').srcObject = mediaScreenStream;
            var streamAttribute = {};
            streamAttribute.userName = userEmail;
            streamAttribute.room = roomId;
            streamAttribute.isScreen = true;
            screenStream = new Owt.Base.LocalStream(mediaScreenStream, new Owt.Base.StreamSourceInfo('screen-cast', 'screen-cast'), streamAttribute);
            this.confrence.publish(screenStream).then(publication => {
                //let operation = [{ op: 'replace',path: '/info/layout',value: this.screenShareLayout}];
                let operation = [{ op: 'add',path: '/info/inViews',value: 'common' }];
                OWT_REST.API.updateStream(roomId, publication.id, operation, function(successResp) {
                    console.log("Stream Added to Mix Stream");
                }, function(status, error) {
                        console.log("Cannot Add Stream to Mix Stream", status, error);
                stream.getVideoTracks()[0].onended = function() {
                    stopScreenShare();
                publication.addEventListener('error', (err) => {
                    console.log('Publication error: ' + err.error.message);
                publication.addEventListener('ended', (err) => {
                    stopScreenShare();
        }, error => {
            console.log("Error Acessing Screen Media:"+error);
I have already published the local stream to conference.
confrence.join(token).then(resp => {
                let connectorId = resp.self.id;
                // audioConstraintsForMic
                let audioConstraints = new Owt.Base.AudioTrackConstraints(Owt.Base.AudioSourceInfo.MIC);
                // videoConstraintsForCamera
                let videoConstraints = new Owt.Base.VideoTrackConstraints(Owt.Base.VideoSourceInfo.CAMERA);
                let mediaStream;
                /* initialise the stream constraints */
                Owt.Base.MediaStreamFactory.createMediaStream(new Owt.Base.StreamConstraints(audioConstraints, videoConstraints)).then(localSystemStream => {
                    let publishOption;
                    if (simulcast) {
                        publishOption = {video: [
                                {rid: 'q', active: true, scaleResolutionDownBy: 4.0},
                                {rid: 'h', active: true, scaleResolutionDownBy: 2.0},
                                {rid: 'f', active: true}
                    mediaStream = localSystemStream;
                    let localStream = new Owt.Base.LocalStream(
                                    mediaStream, new Owt.Base.StreamSourceInfo('mic', 'camera'));
                    console.log("Appending Local stream to video object");
                    document.getElementById(videoTagId).srcObject = localSystemStream;
                    confrence.publish(localStream, publishOption).then(publication => {
                        //publicationGlobal = publication;
                        // inform confrence room to accomodate new stream
                }, err => {
                    console.error('Failed to create Local MediaStream, ' + err.message);
                    conference.leave();
The error is :
Please suggest what to do?
- Ravi
+91-9911990190
